6256 Discussions
Unable to convert retrained tiny-yolo v3 model from DarkNet to Tensorflow and then to IR
Gao__Jiansheng
    I convert tiny-yolo v3 model from DarkNet to Tensorflow and the pb file works normally. Then I convert the pb file to IR by the following command:
            sudo python3 mo_tf.py    \
            --input_model frozen_tiny_yolo_v3.pb    \
            --output_dir save_IR    \
            --data_type FP16    \
            --batch 1    \
            --tensorflow_use_custom_operations_config   yolo_v3_tiny.json
The frozen_tiny_yolo_v3.pb  is converted to IR  successfully.
Then I test the IR by the
    " ~/inference_engine_vpu_arm/deployment_tools/inference_engine/samples/python_samples/object_detection_demo_tiny-yolov3.py" file.
(The file is used for yolov3 at first and I changed it to tiny-yolov3).
The command is:
        python3   object_detection_demo_tiny-yolov3.py  -m  frozen_tiny_yolo_v3.xml  -d  MYRIAD  -i  cam
It works unnormally. It prints the following messages:
            Detected boxes for batch 1:
            [ INFO ] Class ID | Confidence | XMIN | YMIN | XMAX | YMAX | COLOR
            [ INFO ] 0 | 0.513803 | 190 | 4 | 197 | 5 | (0, 0, 0)
            [ INFO ] 0 | 0.587425 | 12 | 13 | 20 | 13 | (0, 0, 0)
           [ INFO ] 1 | 0.700414 | 239 | 6 | 239 | 23 | (12, 7, 5)
           [ INFO ] 1 | 0.526423 | 9 | 4 | 14 | 36 | (12, 7, 5)
           [ INFO ] 0 | 0.522735 | 57 | 16 | 75 | 30 | (0, 0, 0)
          [ INFO ] 1 | 0.524174 | 96 | 8 | 100 | 31 | (12, 7, 5)
          [ INFO ] 1 | 0.749252 | 178 | 16 | 178 | 28 | (12, 7, 5)
         [ INFO ] 0 | 0.513668 | 164 | 7 | 203 | 36 | (0, 0, 0)
         [ INFO ] 1 | 0.588534 | 116 | 22 | 116 | 40 | (12, 7, 5)
        [ INFO ] Layer detector/yolo-v3-tiny/Conv_12/BiasAdd/YoloRegion parameters:
       [ INFO ] num : 3
       [ INFO ] coords : 4
       [ INFO ] anchors : [10.0, 14.0, 23.0, 27.0, 37.0, 58.0, 81.0, 82.0, 135.0, 169.0, 344.0, 319.0]
       [ INFO ] classes : 2
       [ INFO ] Layer detector/yolo-v3-tiny/Conv_9/BiasAdd/YoloRegion parameters:
       [ INFO ] num : 3
       [ INFO ] coords : 4
The num of coordinates is about 200 but it shoule be 1. And the XMIN is equals XMAX.  In addition, the class id shoud only be 1.
When I use the file to test a normal IR, it shows the correct messages:
            [ INFO ] 58 | 0.826624 | 74 | 78 | 129 | 118 | (255, 255, 255)
            [ INFO ] 58 | 0.500350 | 163 | 77 | 218 | 112 | (255, 255, 255)
            [ INFO ] classes : 80
            [ INFO ] coords : 4
            [ INFO ] num : 3
            [ INFO ] coords : 4
            [ INFO ] num : 3
            [ INFO ] coords : 4
            [ INFO ] num : 3
It is normal.  The coordinates are only about the object that is detected and the class id is right.
 I would appreciate if anyone can give some methods to solve this problem.
Thany you,
Gao.
Shubha_R_Intel
Dear Jiansheng:
Instead of -i cam, can you try -i the following video :
person-bicycle-car-detction.mp4  found within
https://github.com/intel-iot-devkit/sample-videos
Please report results here. I'm wondering if it's a problem with -i cam only.
Thanks for using OpenVino !
Shubha
Gao__Jiansheng
Hi Shubha,
I try -i worker-zone-detection.mp4 instead of -i cam to test the IR.  The command is:
    python3 object_detection_demo_tiny-yolov3.py -m frozen_tiny_yolo_v3.xml -d MYRIAD -i worker-zone-detection.mp4
And the result is:
     https://i.loli.net/2019/04/01/5ca1bca3f026d.png
when I use -i cam, the result is:
    https://i.loli.net/2019/04/01/5ca1bd1c1239b.png
And when I use the pb file to test before it is converted to IR, the result is normal:
    https://i.loli.net/2019/04/01/5ca1bd96698f1.jpg
The json file used to convert to IR is:
        "id": "TFYOLOV3",
        "match_kind": "general",
        "custom_attributes": {
        "classes": 2,
        "coords": 4,
        "num": 6,
        "mask": [0,1,2],
        "jitter":0.3,
        "ignore_thresh":0.7,
        "truth_thresh":1,
         "random":1,
         "anchors":[10,14,23,27,37,58,81,82,135,169,344,319],
        "entry_points": ["detector/yolo-v3-tiny/Reshape","detector/yolo-v3-tiny/Reshape_4"]
I  wonder if it is a logical issure.
I would appreciate if you can give some suggestions.
Gao__Jiansheng
@Shubha
Shubha_R_Intel
Dearest Gao, Jiansheng,
You have definitely performed a valid test, so thank you for that. And I agree that the OpenVino IR converted result looks bad. If the same 12 anchor values are being used between the OpenVino and not-OpenVino then the results shouldn't be different.
When you say this : "And when I use the pb file to test before it is converted to IR, the result is normal"  I assume you are using some other method for inference. Which hardware and which method are you using for inference in this case ?
Gao, Jiansheng can you try this test on the just released 2019 R1 ? Also please try both the C++ version and the Python version of object_detection_demo_yolov3_async ?
Shubha
