Unable to run Inference Engine
Pusapati__Satya_Gaja
./object_detection_demo_ssd_async -i "cam" -m "<path/to model optimised .xml file>" -d CPU
bash: ./object_detection_demo_ssd_async: Is a directory
Used the following command from /intel/computer_vision_sdk/deployment_tools/inference_engine/samples
nikos1
Valued Contributor I
Hello Raju,
In the same directory that you run the command object_detection_demo_ssd_async above please run the following to build the samples
mkdir build
cd build
cmake ..
make
Then you can run object_detection_demo_ssd_async from the intel/computer_vision_sdk/deployment_tools/inference_engine/samples/build/intel64/Release folder or whatever other place the binaries were built to.
Cheers,
nikos
