Community
cancel
Showing results for
Search instead for
Did you mean:
Ayaan_T
Use of OPENVINO's DLL in a project compiling with MinGW
Hi folks,
I post this subject even if I found another one that submitted a problem that looked like mine, but I think that I need more explanations.
I am currently developping an application which uses the Openvino's DLL (such as InferenceEngine, Opencv) but I understood that mangles aren't the same when you compile with MSVC and MinGW, so right now if I try to use the libraries from OPENVINO in my CMAKE project, I just have "undefined reference" errors each time I use elements from Openvino.
So my question is the following : Is there a valid and supported way to install OPENVINO with another compiler than the MSVC one, or just without Visual Studio 2019, or is there a way to use the library in a project compiled with MinGW that I don't know ?
Ayaan
Zulkifli_Intel
Hello Ayaan,
Microsoft Visual Studio is required when to use the OpenVINO Toolkit as stated in the OpenVINO installation guide. We advise you to try the OpenVINO™ Deployment Manager as it goes through without Microsoft Visual Studio.
There is a discussion regarding the use of OpenVINOs DLLS with MinGW on this thread for your reference.
Zulkifli
Ayaan_T
Hello Zulkifli,
Thank you for your answer, but even if I use OpenVINO Deployment Manager, the DLLs built with this tool will still be compiled with MSVC so it doesn't solve my mangle problem between MingW and MSVC or am I in the wrong ?
Furthermore, the thread you provided me seems to be my own question..
Ayaan
