Community
cancel
Showing results for
Search instead for
Did you mean:
Ayaan_T
Use of OPENVINO's DLL in a project compiling with MinGW
Hi folks,
I post this subject even if I found another one that submitted a problem that looked like mine, but I think that I need more explanations.
I am currently developping an application which uses the Openvino's DLL (such as InferenceEngine, Opencv) but I understood that mangles aren't the same when you compile with MSVC and MinGW, so right now if I try to use the libraries from OPENVINO in my CMAKE project, I just have "undefined reference" errors each time I use elements from Openvino.
So my question is the following : Is there a valid and supported way to install OPENVINO with another compiler than the MSVC one, or just without Visual Studio 2019, or is there a way to use the library in a project compiled with MinGW that I don't know ?
Ayaan
Zulkifli_Intel
Hello Ayaan,
Microsoft Visual Studio is required when to use the OpenVINO Toolkit as stated in the OpenVINO installation guide. We advise you to try the OpenVINO™ Deployment Manager as it goes through without Microsoft Visual Studio.
There is a discussion regarding the use of OpenVINOs DLLS with MinGW on this thread for your reference.
Zulkifli
Ayaan_T
Hello Zulkifli,
Thank you for your answer, but even if I use OpenVINO Deployment Manager, the DLLs built with this tool will still be compiled with MSVC so it doesn't solve my mangle problem between MingW and MSVC or am I in the wrong ?
Furthermore, the thread you provided me seems to be my own question..
Ayaan
Zulkifli_Intel
Hello Ayaan,
My apologies for the previous response. OpenVINO for Windows is compiled against MSBuild. Generally, OpenVINO requires all the pre-requisite to be available in order for it to work:
1.   Intel® Distribution of OpenVINO™ toolkit core components
2.   Microsoft Visual Studio* with C++ 2019 or 2017 with MSBuild
3.   CMake 3.10 or higher 64-bit
4.   Python 3.6 - 3.8 64-bit
without these, the OpenVINO won't be able to work properly. So, if your project is compiled using MinGW, OpenVINO pre-build libraries will likely fail during linking.
Zulkifli
Ayaan_T
Hello Zulkifli,
Thank you for your response. As I have to use another compiler in my project (Clang or MingW), which are the solutions I can consider to use openvino's libraries inside my solution ?
I have considered to program a C Interface to resolve the mangling issue between the two compilers, but maybe you know other solutions to resolve this compatibility problem or using MSVC is the only "pure C++" option that I have ?
Ayaan
Zulkifli_Intel
Hello Ayaan,
As mentioned in the earlier response, OpenVINO is compiled using MSBuild. If you wanted to explore other compilers, here are the other references for exploration: https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Linking-OpenVINO-DLLs-to-a-program-com.... We hope this will help.
Zulkifli
