6618 Discussions
Why does sample application ./interactive_face_detection_sample not support realsense camera?
rachel_r_Intel
The sample application ./interactive_face_detection_sample uses standard camera by default. Why does it not support realsense camera?
Maksim_S_Intel
When you pass "cam" as input, the app choose first camera (/dev/video0), but on Linux you can provide exact video device: "-i /dev/video2".
You can check all available devices by running: "v4l2-ctl --list-devices". RealSense camera can add two devices - one for video another for depth image, you need the first one.
Monique_J_Intel
Hi Rachel,
Can you paste in the error that you are encountering and the command you used to run the sample?
Kind Regards,
Monique Jones
rachel_r_Intel
Hi Monique,
the command:
./interactive_face_detection_sample -m /opt/intel/computer_vision_sdk/deployment_tools/intel_models/face-detection-adas-0001/FP32/face-detection-adas-0001.xml -m_ag /opt/intel/computer_vision_sdk/deployment_tools/intel_models/age-gender-recognition-retail-0013/FP32/age-gender-recognition-retail-0013.xml -m_hp /opt/intel/computer_vision_sdk/deployment_tools/intel_models/head-pose-estimation-adas-0001/FP32/head-pose-estimation-adas-0001.xml -m_em /opt/intel/computer_vision_sdk/deployment_tools/intel_models/emotions-recognition-retail-0003/FP32/emotions-recognition-retail-0003.xml -d CPU -d_ag CPU -d_hp CPU -d_em CPU -i RealSenseCamera
the error:
InferenceEngine:
	API version ............ 1.2
	Build .................. 13911
[ INFO ] Parsing input parameters
[ INFO ] Reading input
GStreamer: Error opening bin: no element "RealSenseCamera"
(interactive_face_detection_sample:2864): GStreamer-CRITICAL **: gst_element_get_state: assertion 'GST_IS_ELEMENT (element)' failed
[ ERROR ] Cannot open input file or camera: RealSenseCamera
I make sure that realsense camera is connected during the run.
Is it because I used the wrong "-i" parameters?
Thank you very much,
Rachel
Monique_J_Intel
Hi Rachel,
Yes, you have the wrong -i parameter for this sample.
I validated on a Realsense camera and it worked with the following command line please give it a try and let me know if this works for you.
./interactive_face_detection_sample -m /opt/intel/computer_vision_sdk/deployment_tools/intel_models/face-detection-adas-0001/FP32/face-detection-adas-0001.xml -m_ag /opt/intel/computer_vision_sdk/deployment_tools/intel_models/age-gender-recognition-retail-0013/FP32/age-gender-recognition-retail-0013.xml -m_hp /opt/intel/computer_vision_sdk/deployment_tools/intel_models/head-pose-estimation-adas-0001/FP32/head-pose-estimation-adas-0001.xml -m_em /opt/intel/computer_vision_sdk/deployment_tools/intel_models/emotions-recognition-retail-0003/FP32/emotions-recognition-retail-0003.xml -d CPU -d_ag CPU -d_hp CPU -d_em CPU -i cam
Kind Regards,
Monique Jones
rachel_r_Intel
Hi Monique,
Sorry, I use your command to re-run, but it doesn't work for me.
This is my RealSense camera:
root@intel-desktop:/opt/intel/computer_vision_sdk/deployment_tools/inference_engine/samples/build/intel64/Release# lsusb
Bus 002 Device 007: ID 8086:0b07 Intel Corp.
The command:
root@intel-desktop:/opt/intel/computer_vision_sdk/deployment_tools/inference_engine/samples/build/intel64/Release# ./interactive_face_detection_sample -m /opt/intel/computer_vision_sdk/deployment_tools/intel_models/face-detection-adas-0001/FP32/face-detection-adas-0001.xml -m_ag /opt/intel/computer_vision_sdk/deployment_tools/intel_models/age-gender-recognition-retail-0013/FP32/age-gender-recognition-retail-0013.xml -m_hp /opt/intel/computer_vision_sdk/deployment_tools/intel_models/head-pose-estimation-adas-0001/FP32/head-pose-estimation-adas-0001.xml -m_em /opt/intel/computer_vision_sdk/deployment_tools/intel_models/emotions-recognition-retail-0003/FP32/emotions-recognition-retail-0003.xml -d CPU -d_ag CPU -d_hp CPU -d_em CPU -i cam
The error:
InferenceEngine:
(interactive_face_detection_sample:5464): GStreamer-CRITICAL **: gst_element_get_state: assertion 'GST_IS_ELEMENT (element)' failed
VIDEOIO ERROR: V4L: can't open camera by index 0
[ ERROR ] Cannot open input file or camera: cam
But, When I run the same command with Standard camera, everything is ok.
Bus 001 Device 011: ID 045e:0810 Microsoft Corp.
Thank you,
Rachel
Severine_H_Intel
Dear Rachel,
Can VLC read your RealSense camera input? V4L library is also used by VLC.
vlc -vvv v4l2:///dev/video0
Best,
Severine
Maksim_S_Intel
rachel_r_Intel
Thanks all for your help.
I solved my problem with the following command:
./interactive_face_detection_sample -m /opt/intel/computer_vision_sdk/deployment_tools/intel_models/face-detection-adas-0001/FP32/face-detection-adas-0001.xml -m_ag /opt/intel/computer_vision_sdk/deployment_tools/intel_models/age-gender-recognition-retail-0013/FP32/age-gender-recognition-retail-0013.xml -m_hp /opt/intel/computer_vision_sdk/deployment_tools/intel_models/head-pose-estimation-adas-0001/FP32/head-pose-estimation-adas-0001.xml -m_em /opt/intel/computer_vision_sdk/deployment_tools/intel_models/emotions-recognition-retail-0003/FP32/emotions-recognition-retail-0003.xml -d CPU -d_ag CPU -d_hp CPU -d_em CPU -i /dev/video3
And, RealSense camera use three devices:
root@intel-desktop:/opt/intel/computer_vision_sdk/deployment_tools/inference_engine/samples/build/intel64/Release# v4l2-ctl --list-devices
Intel(R) RealSense(TM) 430: Int (usb-0000:00:14.0-4):
	/dev/video1
	/dev/video2
	/dev/video3
Thanks all very much,
Rachel
