hello everyone;
raspberry pi 10 operating system installed
I have problem from ncsdk because I get this error when I try to install the program
how can I fix it?
NCSDK-1.12.01.01/tests/sdk-check/img/512_Phone.jpg
NCSDK-1.12.01.01/tests/sdk-check/data/
NCSDK-1.12.01.01/tests/sdk-check/data/alexnet.prototxt
NCSDK-1.12.01.01/tests/sdk-check/data/googlenet.prototxt
NCSDK-1.12.01.01/tests/sdk-check/data/readme.txt
NCSDK-1.12.01.01/tests/sdk-check/data/squeezenet.prototxt
NCSDK-1.12.01.01/tests/sdk-check/test_install.py
NCSDK-1.12.01.01/ncsdk.conf
NCSDK-1.12.01.01/requirements_apt.txt
Movidius Neural Compute Toolkit Setup.
Checking OS and version...
Your current combination of linux distribution and distribution version is not officially supported!
pi@raspberrypi:~/workspace/ncsdk $ ls
api examples LICENSE ncsdk.conf uninstall.sh
ATTRIBUTIONS install-opencv.sh Makefile README.md
docs install.sh NCSDK-1.12.01.01.tar.gz uninstall-opencv.sh
pi@raspberrypi:~/workspace/ncsdk $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
pi@raspberrypi:~/workspace/ncsdk $ sudo apt-get install lsb-core
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package lsb-core is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'lsb-core' has no installation candidate
Thank you for reaching out.
The NCSDK is no longer being maintained. We recommend you using the OpenVINO™ toolkit, you can review this guide to transition from the Intel® Movidius™ Neural Compute SDK to Intel® Distribution of OpenVINO™ toolkit.
Also, please check the OpenVINO™ toolkit installation guide for Raspbian OS.
Mauricio R.
