6253 Discussions
age-gender-recognition-retail-0013 through cv::dnn API [SOLVED]
Bigorgne__Erwan
The embedded opencv release in openvino 2019 R2 provides a very convenient way to handle the pre-trained net. thanks a lot for that.
But for some reason, I can't get any consistent result with the age-gender-recognition-retail-0013 net (FP32 CPU, the same behavior is observed with FP16/MYRIAD)
                  theNet.setInput(blob,"data");
                  std::vector<cv::Mat> netoutputs;
                  std::vector<cv::String> layers{"age_conv3"};
                  theNet.forward(netoutputs,layers);
                  float age =netoutputs[0].at<float>(0)*100.;
where blob = cv::dnn::blobFromImage(...)
I can't figure out why. The age value takes  random values through the runs.
Dmitry_K_Intel3
Hi!
Can reproduce it with a single output. However works fine if you get both age and gender.
image source: https://github.com/opencv/opencv_extra/blob/master/testdata/gpu/lbpcascade/er.png
Shubha_R_Intel
Dear Bigorgne, Erwan, please study the code of the following demo.  This Demo shows Face Detection coupled with Age/Gender, Head-Pose, Emotion, and Facial Landmarks detectors. Supports video and camera inputs.
Interactive Face Detection C++ Demo
Hope it helps,
Shubha
Bigorgne__Erwan
Hi Shubha, thank you for the reply,
I eventually evaluated the age-gender net using the InferenceEngine API. It works. However, I would have liked to stick to opencv dnn API, as most of our functionnal blocks are based on this latter one.
Despite it seems to be an opencv-related problem, as openvino embeds a release of opencv libraries compiled by your team, I thought it was better to mention this problem here, in an Intel's forum.
All the openvino-zoo models but the age-gender one work great through the cv::dnn API...
Thanks again
Erwan
Shubha_R_Intel
This forum is dedicated to Model Optimizer and Inference Engine. If you are building your Deep Layer application using OpenCV, you will get better response in the OpenCV forum:
https://github.com/opencv/opencv/issues/
Shubha
Kurtaev__Dmitry
Hi!
Can reproduce it with a single output. However works fine if you get both age and gender:
Dmitry_K_Intel3
Hi!
Bigorgne__Erwan
Hi Dmitry,
You are right!! I may dig deeper to know why.
"If you can't get one one correct output, don't bother to get both of them" doesn't apply here...
Thank you very much.
Erwan.
