building error
kashyap__anurag
How i can resolve it..
  File "ageGender.py", line 2, in <module>
    import cv2
ImportError: /opt/intel/openvino/inference_engine/lib/intel64/libinference_engine.so: undefined symbol: _ZN3tbb10interface78internal15task_arena_base24internal_max_concurrencyEPKNS0_10task_arenaE
JAIVIN_J_Intel
Hi Anurag,
Please provide details about the following:
  • Which OS version and OpenVINO version are you using?
  • Can you confirm that PYTHONPATH is set with right directories to import openvino?
            Use the command: echo $PYTHONPATH
  • Are you facing this issue when running any OpenVINO demos or samples?
Jaivin
