Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
change weights at inference time
I need to change graph weights at inference time. However, I didn't find any thing regarding that. Is it possible to access to the weights of graph and change them.
Best,
Community Manager
Hi @mfarhadi
The Movidius graph file is a binary graph file format that isn't open-sourced. So, everything is static and currently there are no plans to release any dynamic graph formats. Once you create the graphs, you cannot change the weight.
You could, however, create two graphs with two difference weights and load them at different times.
Please let me know if this information was helpful.
Sahira
Community Manager
Thanks @Sahira_at_Intel , It was really helpful, do you know what is the fastest way to load a new graph and is there any reference which I can use.
Community Manager
Hi @mfarhadi
You can use the birds example in the NCAPPZOO as a reference for how to load a new graph.
Sahira
