hi,
i am following this link https://docs.openvinotoolkit.org/2020.1/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_CRNN_From_Tensorflow.html
in the third step i was getting AssertionError
frozen = tf.graph_util.convert_variables_to_constants(sess, sess.graph_def, ['shadow/LSTMLayers/transpose_time_major'])
shadow/LSTMLayers/transpose_time_major is not in graph
i changed it to below
frozen = tf.graph_util.convert_variables_to_constants(sess, sess.graph_def, ['shadow_net/sequence_rnn_module/stack_bidirectional_rnn/cell_0/bidirectional_rnn/fw/fw/while/Identity_2'])
and frozen_graph is generated, i am trying to use this frozen graph with this link example https://github.com/opencv/opencv/blob/master/samples/dnn/text_detection.cpp
and opencv throws error
[ERROR:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2020.3\build\windows\opencv\modules\dnn\src\dnn.cpp (3272) cv::dnn::dnn4_v20200310::Net::Impl::getLayerShapesRecursively OPENCV/DNN: []:(_input): getMemoryShapes() throws exception. inputs=1 outputs=0/0 blobs=0
[ERROR:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2020.3\build\windows\opencv\modules\dnn\src\dnn.cpp (3275) cv::dnn::dnn4_v20200310::Net::Impl::getLayerShapesRecursively input[0] = [ 1 1 32 100 ]
[ERROR:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2020.3\build\windows\opencv\modules\dnn\src\dnn.cpp (3285) cv::dnn::dnn4_v20200310::Net::Impl::getLayerShapesRecursively Exception message: OpenCV(4.3.0-openvino-2020.3.0) C:\jenkins\workspace\OpenCV\OpenVINO\2020.3\build\windows\opencv\modules\dnn\src\dnn.cpp:790: error: (-215:Assertion failed) inputs.size() == requiredOutputs in function 'cv::dnn::dnn4_v20200310::DataLayer::getMemoryShapes'
OpenCV: terminate handler is called! The last OpenCV error is:
OpenCV(4.3.0-openvino-2020.3.0) Error: Assertion failed (inputs.size() == requiredOutputs) in cv::dnn::dnn4_v20200310::DataLayer::getMemoryShapes, file C:\jenkins\workspace\OpenCV\OpenVINO\2020.3\build\windows\opencv\modules\dnn\src\dnn.cpp, line 790
i have trained my model from https://github.com/MaybeShewill-CV/CRNN_Tensorflow.git.
i am new to tensorflow , can anyone please have a look
i have uploaded my model to drive https://drive.google.com/drive/folders/1wgFcC3a5jMqcRFvKmj4XFAv_b7ATt9xV?usp=sharing please have a look.
https://github.com/MaybeShewill-CV/CRNN_Tensorflow has not been validated for the C++ Text Detection sample.
Sahira
i also tried to convert it into IR, but got some error
Model Optimizer version:
2020-07-28 17:18:42.925656: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'cudart64_100.dll'; dlerror: cudart64_100.dll not found
2020-07-28 17:18:42.925785: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
[ ERROR ] Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.output_cut.OutputCut'>): Graph contains 0 node after executing <class 'extensions.front.output_cut.OutputCut'>. It considered as error because resulting IR will be empty which is not usual
Hi Amit,
Please provide the command given to Model Optimizer to convert your trained model to Intermediate Representation (IR), and environment details (versions of OS, TensorFlow, Python, CMake, etc.).
Munesh
hi ,
command i tried is
python mo_tf.py --input_model E:\CRNN_Tensorflow-case\frozen_graph_test.pb --reverse_input_channels --data_type FP32 --input_shape="[1,32,100,3]" --output_dir IR
i trained this model in ubuntu 18.04, tensoflow-gpu 1.15, python 3.7
and to convert the frozen_graph i used
windows 10 x64bit machine,
tensorflow-cpu 1.15,
python 3.7
cmake 3.14.5
i have also converted a tensorflow ssd object detection model to IR and that is working fine.
Sahira
