6595 Discussions
create DL Workbench project HTTP Timeout
yufei
Mikhail_F_Intel
Hi Yufei,
The issue is solved. Could you try to run DL Workbench in DevCloud now and let us know if you still observe the issue.
Appreciate your support.
Mikhail
Mikhail_F_Intel
Thank you for reaching out. We observe this issue and currently working with DevCloud team to resolve it. We will update this report once we have more clear picture on the timeline on the fix.
Apologies for the inconvenience caused and stay tuned for updates.
Hairul_Intel
Hi Yufei,
I was able to successfully run the Deep Learning Workbench locally on Docker Desktop in Windows 10.
Which OS are you using? Are you running the DL Workbench in the Intel® DevCloud for the Edge?
Hairul
Mikhail_F_Intel
On my end I observe and reproduce this issue in DevCloud for the Edge only, standalone version doesn't have this problem.
yufei
I'm running the DL Workbench in the Intel® DevCloud for the Edge, not the docker.
Mikhail_F_Intel
Hi Yufei,
Mikhail
