Model Optimizer arguments:
Common parameters:
- Path to the Input Model: /zteam/yuchangcun/models/VesPA_PA100K_26/vespa-pa100k_iter_35000.caffemodel
- Path for generated IR: /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/.
- IR output name: vespa-pa100k_iter_35000
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: Not specified, inherited from the model
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
Caffe specific parameters:
- Enable resnet optimization: True
- Path to the Input prototxt: /zteam/yuchangcun/models/VesPA_PA100K_26/vespa-pa100k_iter_35000.prototxt
- Path to CustomLayersMapping.xml: Default
- Path to a mean file: /zteam/yuchangcun/models/VesPA_PA100K_26/rap_mean.binaryproto
- Offsets for a mean file: Not specified
Model Optimizer version: 1.4.292.6ef7232d
[ ERROR ] Unexpected exception happened during extracting attributes for node inception_4c/double3x3b.
Original exception message: list index out of range
model link:https://github.com/Craigie1996/Pedestrian-Attribute-Recognition/tree/master/models/VesPA_PA100K_26
