What are the reference 35 points of the facial-landmarks-35-adas-0002 network? Only its relative location is explained.
Is there any map/array with the normalized references used for training somewhere?
Hi Ramon,
Thanks for reaching out. The facial-landmarks-35-adas-0002 model is an Intel pre-trained model that is not opened sourced. All public information regarding this model can be found on the models description.
I apologize for the inconvenience.
Jesus
Hi Jesus,
I just mean the 0-1 normalized landmark points used.
One of the use cases for the model is facial alignment, so it's useful to have references.
In https://docs.openvinotoolkit.org/latest/_models_intel_face_reidentification_retail_0095_description_face_reidentification_retail_0095.html there are the 5 keypoints for the landmarks-regression-retail-0009 model.
I was asking if the 35 keypoints are documented similarly somewhere.
you may want to look at gaze_estimation_demo which can use the facial-landmarks-35-adas-0002 model to see how key points handled.
Vladimir
