in freeze_graph.py, line 58, during make in mobilenet example.
from tensorflow.python.training import checkpoint_management
will report error 'can not import name checkpoint_management'.
if I change it to import checkpoint_management and move checkpoint_management.py to the same directory with freeze_graph.py,
compilation works without error.
I have tried it on two laptops, $PYTHONPATH is /opt/movidius/caffe/pyhton.
Is there any steps I miss?
- Tags:
- Tensorflow
@Curry This is a known issue. The TensorFlow freeze_graph.py script changed and you'll have to refer back to a previous commit in the TensorFlow github.
Just updated the NCAPPZOO github repo. Please try re-cloning the ncappzoo and trying again. Thanks.
@Tome_at_Intel
Thanks for your help. It works fine.
Hi
I am facing the same problem. Kindly advise.
Umer
Topic Options
