6584 Discussions
gvawatermark unable to adapt the meta information when input source changes its resolution run-time
NikhilP
We are trying to do a "Person / Vehicle / Bike" detection using Intel OpenVINO 2021.4.2 version.
The input source is a 3gp clip of 36 sec duration. For the first 18 sec the resolution is 360p and for the next 18 sec its 720p.
When we try to do a inferencing on the clip, we see that the "gvawatermark" is unable to adapt the meta information when the resolution changes run-time from 360p->720p.
This causes the pipeline to crash eventually.
Steps to reproduce
1) Setting up Environment:
source /opt/intel/openvino_2021.4.752/bin/setupvars.sh
source /opt/intel/openvino_2021.4.752/data_processing/dl_streamer/bin/setupvars.sh
2) Model Files Downloaded from below path:
https://storage.openvinotoolkit.org/repositories/open_model_zoo/2021.4/models_bin/3/person-vehicle-bike-detection-2004/FP32/person-vehicle-bike-detection-2004.xml
https://storage.openvinotoolkit.org/repositories/open_model_zoo/2021.4/models_bin/3/person-vehicle-bike-detection-2004/FP32/person-vehicle-bike-detection-2004.bin
3) Pipeline Command:
gst-launch-1.0 filesrc location=/dsp/gvaWatermarkIssue/PBV_360p_720p.3gp ! decodebin ! queue ! gvadetect model=./model/person-vehicle-bike-detection-2004.xml de
vice=CPU threshold=0.5 inference-interval=5 ! gvatrack tracking-type=short-term-imageless ! gvawatermark ! videoconvert ! fakesink sync=true
NOTE: "PBV_360p_720p.3gp" is archived in the attached zip file.
4) Error thrown by the pipleine:
** (gst-launch-1.0:53): CRITICAL **: 13:44:33.928: gst_video_frame_map_id: assertion 'info->width <= meta->width' failed
ERROR: from element /GstPipeline:pipeline0/GstGvaWatermark:gvawatermark0/GstGvaWatermarkImpl:gvawatermarkimpl: gvawatermark has failed to process frame.
Additional debug info:
/root/gst-video-analytics/gst/elements/gvawatermark/gstgvawatermarkimpl.cpp(266): gst_gva_watermark_impl_transform_ip (): /GstPipeline:pipeline0/GstGvaWatermark:gvawatermark0/GstGvaWatermarkImpl:gvawate
rmarkimpl:
While this behaviour of clients changing the resolution on  the fly is a common use case, we do see that the gvawatermark is unable to hab=ndle such changes and eventually crashes.
Will this be fixed and such a support be added ?
Nikhil
Iffa_Intel
I don't see that error from my end
Note: it's recommended to use a newer version of OpenVINO as in this guide.
Cordially,
Iffa
NikhilP
Thank you for your quick response.
I have also checked and the issue is not seen with OpenVINO 2022 version.
The issue can be closed.
Nikhil
Iffa_Intel
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
