installer errors
Nedregård__John
Hi trying to install the Toolkit on the latest Ububtu version, but even when i follow the recipe it fails.
Several errors occur during the normal installation - missing files, non existing folder ++ all installed with use of sudo.
Then I tries to install tf, but that is also failing?
sudo ./install_prerequisites_tf.sh
Hit:1 https://download.docker.com/linux/ubuntu eoan InRelease
Hit:2 http://no.archive.ubuntu.com/ubuntu eoan InRelease
Hit:3 http://ppa.launchpad.net/ozmartian/apps/ubuntu eoan InRelease
Get:4 http://security.ubuntu.com/ubuntu eoan-security InRelease [97,5 kB]
Hit:5 http://no.archive.ubuntu.com/ubuntu eoan-updates InRelease
Ign:6 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:7 http://no.archive.ubuntu.com/ubuntu eoan-backports InRelease
Hit:8 http://dl.google.com/linux/chrome/deb stable Release
Hit:9 https://download.docker.com/linux/ubuntu zesty InRelease
Hit:10 https://download.docker.com/linux/ubuntu bionic InRelease
Fetched 97,5 kB in 1s (68,0 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
E: Unable to locate package libgfortran3
Error on or near line 75; exiting with status 1
Earlier on I believed it was because of other installed tools and utilities, so I have reinstalled a clean Ubuntu, upgraded it and still the same issues occurs.
Is this installation tested on a clean environment. It seams like it has dependencies to elements not included in the install package?
SIRIGIRI_V_Intel
Hi John,
OpenVINO toolkit(version 2019_R3 onwards) supports Ubuntu 18.04.x.
Which version of Ubuntu and OpenVINO are you using?
Please verify that you are following the operating system requirements.
Ram prasad
