6597 Discussions
internal compiler error: Segmentation fault
Deepak_C_R
I am getting following error while compiling openvx_sample code.
samples/face_detection/CMakeFiles/face_detection_user_nodes_module.dir/face_detection_user_nodes_module.cpp.o
[ 32%] Linking CXX shared library libface_detection_user_nodes_module.so
[ 32%] Built target face_detection_user_nodes_module
Scanning dependencies of target face_detection
[ 32%] Building CXX object samples/face_detection/CMakeFiles/face_detection.dir/face_detection.cpp.o
/home/uncanny/IntelR_Computer_Vision_SDK_Beta_2017R2_samples/samples/face_detection/face_detection.cpp: In function ‘_vx_graph* CreateFaceDetectionGraph(vx_context, vx_image, vx_uint32, vx_uint32, vx_float32, vx_bool, vx_enum, const CmdParserFaceDetection&, vx_bool, vx_uint32, std::vector<_vx_node*>&, std::vector<const char*>&, std::vector<_vx_array*>&)’:
/home/uncanny/IntelR_Computer_Vision_SDK_Beta_2017R2_samples/samples/face_detection/face_detection.cpp:312:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-5/README.Bugs> for instructions.
samples/face_detection/CMakeFiles/face_detection.dir/build.make:62: recipe for target 'samples/face_detection/CMakeFiles/face_detection.dir/face_detection.cpp.o' failed
make[2]: *** [samples/face_detection/CMakeFiles/face_detection.dir/face_detection.cpp.o] Error 1
CMakeFiles/Makefile2:730: recipe for target 'samples/face_detection/CMakeFiles/face_detection.dir/all' failed
make[1]: *** [samples/face_detection/CMakeFiles/face_detection.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
What could be the reason for same ?
Stav_S_Intel
What version is this? can you also share the bug file?
Stav
