6594 Discussions
live-image-classifier.py", line problem
Hi. I have a problem for movidius AI. my problem is below. please help me step by step
pi@AI:~ $ cd ncappzoo/apps/live-image-classifier
pi@AI:~/ncappzoo/apps/live-image-classifier $ python3 live-image-classifier.py
File "live-image-classifier.py", line 186, in
main()
File "live-image-classifier.py", line 131, in main
img, frame = pre_process_image()
File "live-image-classifier.py", line 63, in pre_process_image
height, width, channels = frame.shape
AttributeError: 'NoneType' object has no attribute 'shape'
Dear colleagues I have the same issue.
I'm using a raspberry 3, running strech.
I had a hard time to get the SDK2 + NCAPPZOO running. I had to manually install:
-Cython
-Opencv
-All Opencv requisites
taxWarning: assertion is always true, perhaps remove parentheses?
assert(False, "Layer type not supported by Convolution: " + obj.type)
mvNCCompile v02.00, Copyright @ Intel Corporation 2017
/usr/local/bin/ncsdk/Controllers/FileIO.py:65: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
Blob generated
make[1]: Leaving directory '/home/pi/ncsdk/ncappzoo/caffe/AgeNet'
Running live-image-classifier.py
python3 live-image-classifier.py --graph ../../caffe/AgeNet/graph --labels ../../data/age_gender/age_categories.txt
File "live-image-classifier.py", line 191, in
main()
File "live-image-classifier.py", line 136, in main
File "live-image-classifier.py", line 65, in pre_process_image
Makefile:41: recipe for target 'run' failed
make: *** [run] Error 1
@Intel guys, could you please assist?
I'm loosing my hope to get this Movidius stick working. Thanks in advance!
Dear all,
I've updated and upgreded the OS and restarted and it is now working.
I am proof the examples for the sticks work and I am pretty much a novice at all of this.
