make examples error
Hi experts
I have just done make examples and got the following error (below). Any hints?
make examples
./install-opencv.sh
All fine. Until:
making caffemodel
Downloading caffemodel file
--2018-08-29 20:42:23-- http://dl.caffe.berkeleyvision.org/bvlc_googlenet.caffemodel
Resolving dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)… 169.229.222.251
Connecting to dl.caffe.berkeleyvision.org (dl.caffe.berkeleyvision.org)|169.229.222.251|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 53533754 (51M) [application/octet-stream]
Saving to: ‘./bvlc_googlenet.caffemodel’
bvlc_googlenet.caff 100%[===================>] 51.05M 915KB/s in 67s
2018-08-29 20:43:30 (781 KB/s) - ‘./bvlc_googlenet.caffemodel’ saved [53533754/53533754]
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
/usr/lib/python3/dist-packages/scipy/stats/morestats.py:16: DeprecationWarning: Importing from numpy.testing.decorators is deprecated, import from numpy.testing instead.
from numpy.testing.decorators import setastest
Makefile:80: recipe for target 'compile' failed
make[4]: *** [compile] Illegal instruction (core dumped)
make[4]: Leaving directory '/home/ubuntu/ncsdk-2.05.00.02/examples/caffe/GoogLeNet'
cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
Makefile:9: recipe for target 'googlenet' failed
make[3]: *** [googlenet] Error 1
make[3]: Leaving directory '/home/ubuntu/ncsdk-2.05.00.02/examples/apps/multistick_cpp'
Makefile:13: recipe for target 'multistick_cpp/.' failed
make[2]: *** [multistick_cpp/.] Error 2
make[2]: Leaving directory '/home/ubuntu/ncsdk-2.05.00.02/examples/apps'
Makefile:12: recipe for target 'apps/.' failed
make[1]: *** [apps/.] Error 2
make[1]: Leaving directory '/home/ubuntu/ncsdk-2.05.00.02/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
bv
@sojohan One user mentioned solving this issue by reinstalling OpenCV @ https://ncsforum.movidius.com/discussion/906/make-error-127/p1. Also make sure to open a new terminal window when running make examples after installing the NCSDK.
Hi Tome@Intel
Will try the hints…..
sojohan
