make examples error
Hi experts
I still get this error: Any ideas?
making caffemodel
caffemodel file already exists
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
Makefile:80: recipe for target 'compile' failed
make[4]: *** [compile] Illegal instruction (core dumped)
make[4]: Leaving directory '/home/ubuntu/ncsdk-2.05.00.02/examples/caffe/GoogLeNet'
cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
Makefile:9: recipe for target 'googlenet' failed
make[3]: *** [googlenet] Error 1
make[3]: Leaving directory '/home/ubuntu/ncsdk-2.05.00.02/examples/apps/multistick_cpp'
Makefile:13: recipe for target 'multistick_cpp/.' failed
make[2]: *** [multistick_cpp/.] Error 2
make[2]: Leaving directory '/home/ubuntu/ncsdk-2.05.00.02/examples/apps'
Makefile:12: recipe for target 'apps/.' failed
make[1]: *** [apps/.] Error 2
make[1]: Leaving directory '/home/ubuntu/ncsdk-2.05.00.02/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
Hi
I have now reinstalled opencv
installed updated python*-decorate
installed scikit-image
Still the same error as above…..
sojohan
@sojohan Can you please try the following steps and let me know if this works for you?
  1. Uninstall your ncsdk installation using the uninstall.sh script in the ncsdk folder.
  2.
  3. Delete your ncsdk folder.
  4.
  5. Redownload a copy of the ncsdk using the command wget https://ncs-forum-uploads.s3.amazonaws.com/ncsdk/ncsdk-02_05_00_02-full/ncsdk-2.05.00.02.tar.gz
  6.
  7. Install the ncsdk using the command make install
  8.
  9. Close the installation terminal. Open a new terminal window (so that the pythonpath is set by bashrc).
  10.
  11. In the new terminal window, navigate to the ncsdk install folder and build the samples using make examples or alternatively go to a desired sample and run the command make run to build and run the sample.
  12.
More samples are available in the ncappzoo @ https://github.com/movidius/ncappzoo/. You can download the samples using the command git clone -b ncsdk2 https://github.com/movidius/ncappzoo for ncsdk version 2.
Hi Tome@Intel
Thanks for the help.
But I get the same error in make example.
@sojohan Can you try running each of the examples in the ncsdk/ncappzoo folder and let me know which ones work for you and which ones don't?
I think the ncsdk might have installed correctly but there may be something with the makefile from GoogLeNet that is causing it to fail.
Hi Tome@Intel
Good news…I got it to work.
The problem is that Tensorflow from version1.6 uses AVX and my machine does not. So I installed Tensorflow 1.5 instead.
I also think that I got the wrong ncsdk/ncappzoo file:
git clone https://github.com/movidius/ncappzoo
But should have used:
git clone -b ncsdk2 https://github.com/movidius/ncappzoo.git
So now I can run all the examples….
Thanks again
sojohan
@sojohan Glad to hear it's working for you!
