6584 Discussions
make: execvp: ./uninstall-opencv.sh: Text file busy
I'm trying to build ncsdk with docker per the official instructions: https://movidius.github.io/ncsdk/docker.html
When I run: docker build -t ncsdk -f ./extras/docker/Dockerfile https://github.com/movidius/ncsdk.git#ncsdk2
I get: make: execvp: ./uninstall-opencv.sh: Text file busy
Full output:
$ docker build -t ncsdk -f ./extras/docker/Dockerfile https://github.com/movidius/ncsdk.git#ncsdk2
Sending build context to Docker daemon 156 MB
Step 1/5 : FROM ubuntu:16.04
---> e13f3d529b1a
Step 2/5 : RUN apt-get update && apt-get install -y build-essential sed sudo tar udev wget && apt-get clean
---> Using cache
---> fdb8fb24da8a
Step 3/5 : COPY ./ ncsdk/
---> 0571e1c68c0f
Removing intermediate container f709f2d4d324
Step 4/5 : WORKDIR "/ncsdk"
---> b578d2146cec
Removing intermediate container 79d963e4cf6d
Step 5/5 : RUN make install
---> Running in 19a226ff30c7
Makefile:27: recipe for target 'uninstallopencv' failed
make: *** [uninstallopencv] Error 127
The command '/bin/sh -c make install' returned a non-zero code: 2
Yet, when I go into the docker container with docker run -it a3ab6a2231f8 /bin/bash and run ./uninstall-opencv.sh, it succeeds:
root@3ddf9f7bec3d:/ncsdk# ./uninstall-opencv.sh
OpenCV uninstall starting
Reading installer configuration variables from ./ncsdk.conf
OpenCV uninstall finished
What could be the problem?
Note:
The official instructions say to use docker-ce, but I'm using docker 1.13.1
Solved: use docker-ce.
