I have a trained caffe model, when I use the command :
mvNCCompile deploy.prototxt -w mobilenet_iter_300000.caffemodel -s 12 -on Mconv7_stage4 -o mob_cpm.graph
I got the message:
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 169, in
create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args)
File "/usr/local/bin/mvNCCompile", line 148, in create_graph
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 103, in load_network
parse_ret = parse_caffe(arguments, myriad_conf)
File "/usr/local/bin/ncsdk/Controllers/CaffeParser.py", line 1162, in parse_caffe
for i in range(len(top)):
TypeError: object of type 'NoneType' has no len()
I don't know what the matter it is
plz help me , appreciate!
hi you can use mvNCCheck for first to make sure it can work normally
