object detection zoo resnet v50 fpn coco failing after transfer learning
Connolly__John
I downloaded the ssd_resnet_v50 fpn network from tensorflow,, and then ran the mo_tf.py script that comes packaged with openvino
with the following input args
python3 /opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py \
--saved_model_dir ~//Downloads/resnet/ssd_resnet50_v1_fpn_shared_box_predictor_640x640_coco14_sync_2018_07_03/saved_model \
--tensorflow_object_detection_api_pipeline_config ~//Downloads/resnet/ssd_resnet50_v1_fpn_shared_box_predictor_640x640_coco14_sync_2018_07_03/pipeline.config \
--tensorflow_use_custom_operations_config /opt/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf/ssd_v2_support.json \
--reverse_input_channels
and everything worked like a charm.
I then used the object detection api to do transfer learning on this stock model. I converted my stock model wtih the script at models/research/object_detection/export_inference_graph.py
Then I tried again to convert to openvino using the following command:
--saved_model_dir ~/old_models/v21/saved_model/ \
--tensorflow_object_detection_api_pipeline_config ~/old_models/v21/pipeline.config \
--tensorflow_use_custom_operations_config ~/old_models/v21/ssd_v2_support.json \
and now I get the following error output:
[ ERROR ]  Failed to match nodes from custom replacement description with id 'ObjectDetectionAPIPreprocessorReplacement':
It means model and custom replacement description are incompatible.
Try to correct custom replacement description according to documentation with respect to model node names
[ ERROR ]  Failed to match nodes from custom replacement description with id 'ObjectDetectionAPISSDPostprocessorReplacement':
[ ERROR ]  Cannot infer shapes or values for node "Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/Select_4".
[ ERROR ]
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function Select.infer at 0x7fa50799fd08>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ]  Run Model Optimizer with --log_level=DEBUG for more information.
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/Select_4" node.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
I have tried with the ssd_v2_support.json and ssd_support_api_v1.14.json, neither succeed.
I am using pytthon3.6 with tensorflow 1.14
Shubha_R_Intel
Dear Connolly, John,
Can you try adding:
right after   "Postprocessor/ToFloat" in your ssd_v2_support.json ?
 "start_points": [
                "Postprocessor/Shape",
                "Postprocessor/scale_logits",
                "Postprocessor/Tile",
                "Postprocessor/Reshape_1",
                "Postprocessor/ToFloat",
You didn't attach the full debug log so I'm not sure exactly where it fits in. You'd be able to tell by perusing the log with the following switch --log_level DEBUG.
Let me know if this works for you.
Shubha
Connolly__John
Thank you for the prompt feedback. Unfortunately that did not work for me - I have attached the debug output from this attempt.
I'm having trouble understanding what you mean here, could you explain what should be fitting where?
Shubha_R_Intel
In fact, the file you attached is the DEBUG log print obtained by passing in --log_level DEBUG. Thank you for that. I really think this may be a Model Optimizer bug, based on what you have told me. Before training, no problems, MO worked like a charm. After training, it broke. Yep, I've seen this before. And the reason it happens is because the Tensorflow model changes underneath us. I have PM'd you so that you can privately send me your trained model.
We'll definitely get back to you with an answer and hopefully a solution also.
Sorry for the inconvenience and thanks for using OpenVino !
Shubha
Shubha_R_Intel
I have reproduced your issue and filed a bug. I will definitely update you once a resolution has been found.
Shubha
Shubha_R_Intel
Dear John and everyone, it looks like John was able to succeed with the attached revised *.json file. If anyone else runs into the same issue as John, feel free to use this json file for the -tensorflow_use_custom_operations_config argument.
Thanks !
Shubha
