Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
readNetFromModelOptimizer An error occurred
static const char* names[] = { "dog.jpg",
        //"xu_2_4.jpg",
        //"xu_3_128.jpg","xu_1_153.jpg","xu_5_101.jpg","xu_8_90.jpg","xu_8_208.jpg",
        0
    //string imgname = "guo_0_img60";
    //string img_path = imgname.append(".jpg");
    //Net net = readNetFromDarknet(model_def, model_weights);
    String name_file = "coco.names";
    string binModel = "E:/pb/yolo_v3.bin";
    string xmlInfo = "E:/pb/yolo_v3.xml";
    Net net = readNetFromModelOptimizer(xmlInfo, binModel);
    net.setPreferableBackend(DNN_BACKEND_INFERENCE_ENGINE);
    net.setPreferableTarget(DNN_TARGET_CPU);
When the program is executed at readNetFromModelOptimizer, the  program is  aborted,is the problem of that OpenVINO enviroment?
Can you please provide more information about the error message you're getting? Are you running a custom model or a pretrained one?
Sahira
