stream infer python with no window
I'm using the stream_infer.py script, that I've found here:
https://github.com/movidius/ncappzoo/blob/master/apps/stream_infer/stream_infer.py
It works perfectly, but it's possible to run it, but without open any streaming window? Like if the work is in the background?
Hi @accat
I don't think you would be able to take out the part of the code that builds the GUI since the stream is sent to the window itself. Is there any particular reason that you would want to accomplish this?
Sincerely,
Sahira
