super_resolution_demo with GPU/MYRIAD Failed
SC_Huang
I've try the demo with error as below
200x200
with single-image-super-resolution-0063(FP32) GPU:
[ INFO ] Loading model to the plugin
[ ERROR ] network allocation failed: exceeded max size of memory object allocation
with single-image-super-resolution-0063(FP16) GPU:
[ ERROR ] network allocation failed: /teamcity/work/scoring_engine_build/releases_2018_R5/thirdparty/clDNN/src/reshape.cpp at line: 64
Error has occured for: 352
Output layout count(=20480000) is not equal to: input layout count(=0)
Output layout of reshape pirmiti
with single-image-super-resolution-0063(FP16) MYRIAD:
[usb_read:365] error=-1, total size is=36,leave size=36
E: [xLink] [         0] dispatcherEventReceive:304    dispatcherEventReceive() Read failed -1 | event 0x7f94d4ff8eb0 USB_CLOSE_STREAM_RESP
E: [xLink] [         0] eventReader:254    eventReader stopped
E: [xLink] [     52715] dispatcherWaitEventComplete:720    waiting is timeout, sending reset remote event
also similar problem in other model like single-image-super-resolution-1011,1021
so, what cause the error happened?
Is there any solution or it just not support plugin except mkldnn?
nikos1
Valued Contributor I
According to https://software.intel.com/en-us/openvino-toolkit/documentation/pretrained-models only CPU path ( -d CPU ) is supported for Super resolution samples ( Supported Samples Table : Reference this table for components that support the pretrained models. )
So yes, it looks only mkldnn for now as you said.
SC_Huang
nikos wrote:
According to https://software.intel.com/en-us/openvino-toolkit/documentation/pretrain... only CPU path ( -d CPU ) is supported for Super resolution samples ( Supported Samples Table : Reference this table for components that support the pretrained models. )
Hi Nikos,
Thanks for your kindly reply~
