6426 Discussions
the needed input size of tensor is not match the network.
416 is real number i input and work.
the network says input 448*448 size ,but if i input this size pictrue it will have problem.i use 416 it's ture. what's more the output is also different from the need;.so i an not deal with it ;all happens when i use the tiny yolo and want change the python api to c++;
