6597 Discussions
ubuntu 18.04 install failure InRelease 403 Forbidden [IP: 52.218.52.129 80]
Trying to install on laptop with UBuntu 18.04 downloaded the ncsdk then ran the
make install
First it failed because version check was looking for 1604.
Replaced the version check for 1604 not I have this and no idea how to fix it.
Now I got this.
Not sure how to fix it.
E: Failed to fetch http://realsense-alm-public.s3.amazonaws.com/apt-repo/dists/xenial/InRelease 403 Forbidden [IP: 52.218.52.129 80]
E: The repository 'http://realsense-alm-public.s3.amazonaws.com/apt-repo xenial InRelease' is not signed.
Installation failed: Command ' apt-get update' return code=100. Error on line 308 in ./install-utilities.sh. Will exit
Makefile:47: recipe for target 'install' failed
make: *** [install] Error 131
Re wrote what the issue is. I haven't slept much..
Trying to install ncsdk failure onto a laptop.
OS version ubuntu 18.04
Ran
git clone -b ncsdk2 https://github.com/movidius/ncsdk.git
then
make install
First failure, version check looking for version 1604 in the install.sh file.
Replaced with version 1804 which fixed the problem.
Re run
make install
I get
@chicagobob123
xenial -> bionic
Do you mean to do this?
http://realsense-alm-public.s3.amazonaws.com/apt-repo/dists/bionic/InRelease
instead of this.
I still get this error
Access Denied
B617219C8EC89DC0
lEYGg0gNuZkOb4Vw0I+5SBET88VafR8ZBeayJGXk0FKBpo9lZNDnqj83oVcEgzkcDs+PLgvy2sc=
I should have read the errata which said only version 16.04 is supported not 18.04
That's disappointing.
