Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
64-bit Assembler
Jamils
Hi there,
I would like to know if Intel has a 64-bit Assembler, if not, which assembler you recommend to use for Assembly Programming?
JesusE_Intel
Hi Jamils,
I recommend posting your question on the compiler forums for an accurate suggestion. There is a similar discussion that may be helpful to you. Solved: Assembly Language Programming - Intel Communities
Jesus
JesusE_Intel
Hi Jamils,
Jesus
JesusE_Intel
