Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
Client node going offline
Snehal_Yesugade
Hi
As part of testing at custom place, in CSL setup, CSL manager is restarted. Once the manager was back, we could see the client nodes are enlisted but one of those is offline
Request your help on this
WengWai_C_Intel
@Snehal_Yesugade As per investigation, since the CSL setup is within a custom network configuration with ports access restriction, the ports that being used by CSL need to be reconfigured upon system reboot. For long run, suggestion is to work with the network administrator to configure the ports persistent for CSL application if possible. Alternatively, just need to create a bash script to auto reconfigure the ports upon system reboot. Hope these can give an idea to move forward. Thanks!
WengWai_C_Intel
Sahira_Intel
Hi.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Sincerely,
Sahira
