Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
Csl Sever Installation
Rajnish
i an getting following error while installing csl server:-
dev@dev-NUC8i3BEH:~/edge_insights_industrial/Edge_Insights_for_Industrial_2.3.2/orchestrator/orchestrator/server-package$ /bin/bash server-bootstrap.sh
*** [Start] Bootstrap CSL Server Version 1.5.3483-a0f1d8e9 ***
{INFO}: Running on ubuntu 18.04
Could not find a valid Docker daemon configuration json file.
Creating /etc/docker/daemon.json file with attributes 'iptables' = false and 'ip-masq' = false
Restarting Docker daemon
Docker daemon is running with the new configuration
{ERR}: There has been an error while trying to check if server node name exist. Please, refer to CSL Manager logs for more information.
I have attached the csl manager logs screensort.Any help is appreciated.
WengWai_C_Intel
Hi @Rajnish ,
There was a same question asked earlier, you can refer to this link for the answer. Let me know if this able to help address your issue. Thanks!
https://community.intel.com/t5/Intel-Edge-Software-Hub/CSL-Orchestration/m-p/1218989#M263
Rajnish
This issue is resolved .kindly ignore this.
WengWai_C_Intel
Thank you for letting us know.
