Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
378 Discussions
DHCP range format Edge Software Configurator
syaza
I need to setup Edge Software Configurator and the specification have meet the requirements.
During the setup it ask for DHCP range and I try to enter the range but it keep on pop up out of range.
I think I have put the right range but what kind of format for the range should I use? Is it
xxx.xxx.xx.x - xxx.xxx.xx.x or xxx.xxx.xx.x : xxx.xxx.xx.x or no need to put anything just put the space between 2 range
JesusE_Intel
Hi syaza,
You should give the installer a DHCP range in xxx.xxx.xxx.xxx/xx format. For example: 192.168.10.0/24. I recommend using nmcli device show <interface name> to see your systems network details.
Jesus
JesusE_Intel
Hi syaza,
Jesus
JesusE_Intel
