Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
Deployment with error
WeiSeng
Hi Team,
I try to set up smart edge open with follow this guide:
https://edc.intel.com/content/www/us/en/design/technologies-and-topics/iot/seodek/1.0/
have the error shown picture in attached. Any suggestion to solve the issue?
JesusE_Intel
Hi WeiSeng,
It looks like the wheel package cannot be found. Could you try to manually install it and run the deploy command once more?
apt update
python3 -m pip install --upgrade pip
pip install wheel==0.37.1
Jesus
SShan_Intel
Hi WeiSeng,
Try edit /etc/apt/sources.list , those lines that has http://my.archive.ubuntu.com , remove my. and become http://archive.ubuntu.com . Then check again if you still encounter the issue.
SShan_Intel
WeiSeng
Hi SShan,
Thanks for your support.
Today I try deploy with command '$pipenv run ./deploy.py' getting error attached.
You have any suggestion?
JesusE_Intel
Hi WeiSeng,
apt update
Jesus
JesusE_Intel
