Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
EDTDT installaion
Shigeyoshi_O_Intel
I download EDTDT and try to install EDTDT in my desktop machine (Ubuntu 18.04.5) with the command (./edgesoftware install), but the completion message is different from one in get started manual.
When I find the module ID with the command (./edgesoftware list --default), it returns below. The module ID cannot be found in the installation folder.
May I ask what's wrong with the procedure?
Nadia_J_Intel
Hi Shigeyoshi,
It seems like the system didn't fully installed the needed components. You see the list below once the installation is finished. May I know your installed version ?
May I know your installation version ? you can insert the command
$ ./edgesoftware -v
and see from the output of this command.
Shigeyoshi_O_Intel
Hello Nadia,
Thank you so much. The message says version 2020.1.
Ohara
Nadia_J_Intel
Hi Shigeyoshi,
Can you download the latest installation package for the EDTDT and try that ? We have a newer version in our download page for EDTDT.
Shigeyoshi_O_Intel
Hi Nadia,
Thank you so much. It works now. It seems that I missed something.
I appreciate your help.
Ohara
