Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
404 Discussions
EI for AMR v2021.3 (Q3 2021 Release) Navigation issue
Nadia_J_Intel
Hi all,
There is a known navigation issue for the Nav2 planner stack.
While navigating, the Robot looses or resets the costmap it created previously. Nav2 path planner creates a path through the wall and hits it.
It is a known bug in Nav2 path planner and similar to what has been reported at: https://github.com/ros-planning/navigation2/issues/1999
A patch will be available soon to fix the issue.
Nadia_J_Intel
Hi all,
As mentioned, the fix patch for the above issue is attached below. There is a readme in the zip file to help you execute the patch.
Nadia_J_Intel
Hi all,
