Intel® Edge Software Hub
Get help on building Edge Software Hub solutions for edge compute node
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
316 Discussions
EII package install failed
Jerry4_Liu
Hello all,
I am getting the following error message when installing EII packages:
Failed to update packages python3 builder.py
Failed to install eii_installer took 1 minutes 49.23 seconds
I have try reinstall python, but still have errors.
Does anyone know some clues to cope with this problem~?
Please see attached screenshot from my terminal~
-Jerry
JesusE_Intel
Hi Jerry,
I just installed Edge Insights for Industrial version 2.6.2 on a fresh Ubuntu 18.04 system successfully. Are you using a fresh Ubuntu 18.04 system? Do you see the same error message when re-running the installation?
Could you please share the installation log file? The log file is located in the following directory:
/var/log/esb-cli/Edge_Insights_for_Industrial_2.6.2/eii_installer/install.log
Jesus
Jerry4_Liu
Hello JesusE,
This is my install.log
-Jerry
JesusE_Intel
Hi Jerry,
For some reason I am unable to download or open the log file (Forbidden error). Would you mind attaching it again?
Jesus
Jerry4_Liu
Hello JesusE,
-Jerry
Jerry4_Liu
Hello JesusE,
sorry, I don't know why my file can't be download, I will try it again
-Jerry
Jerry4_Liu
Hello JesusE,
May I have your Hardware specification and OS version
mine could be see in attached file
-Jerry
JesusE_Intel
Hi Jerry,
I am using an Intel NUC with an Intel® Core™ i5-9300H CPU running a fresh Ubuntu 18.04. LTS.
Thanks for sharing the log file! I was able to download and open it, however, it does not have as much information as I was hoping. You mentioned you re-installed python, which python version are you using?
Is it possible for you to try to install the software package on a system with a clean install of Ubuntu 18.04?
Jesus
Jerry4_Liu
Hello JesusE,
I use command line to see the python version:
python --version  : Python 2.7.17
python3 --version : Python 3.6.9
-Jerry
JesusE_Intel
Hi Jerry4_Liu,
The python versions are the same on my system. I retested today on a fresh OS install and did not run into any issues with the installation. I recommend trying the installation process on a system with a fresh OS (Ubuntu 18.04).
Please give it a try and let me know if you run into any issues.
Jesus
JesusE_Intel
