Hi @Mauricio
May I know if this error is showing by using the Download Version 2.3.1? if yes, you can get the new Download Version 2.3.2 and continue to use the user guide for the manual installation because for the new release this orchestrator component will not be auto-installed.
Previously you mentioning that you only need the video analytics component to be installed. In that case, you can use the customize and download. You can uncheck for this component and proceed to install the package.
Hi @Mauricio
Thank you very much for your help.
