Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
401 Discussions
ERROR - Failed to install Automated_License_Plate_Recognition. tuple index out of range
MohammedSaif
Hi everyone,
I am trying to implement the following use case on a Ubuntu Machine.
https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/automated-license-plate-recognition.html
However, i keep getting this error - Failed to install Automated_License_Plate_Recognition. tuple index out of range.
Ubuntu version - 20.04.4 LTS
Last few lines of the log file-
Wed Aug 03 02:12:53 IST 2022 - ERROR - Failed to install Automated_License_Plate_Recognition. tuple index out of range
Wed Aug 03 02:12:53 IST 2022 - INFO - Updating status in log file for Automated_License_Plate_Recognition as FAILED
Wed Aug 03 02:12:53 IST 2022 - INFO - Successfully updated status in log file for Automated_License_Plate_Recognition
Wed Aug 03 02:12:53 IST 2022 - ERROR - Failed to connect. Please check the Internet connection and proxy settings and retry. HTTPSConnectionPool(host='edgesoftwarehub.intel.com', port=443): Max retries exceeded with url: /recipe/6241c176bc27a5002cca6692 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8d51b5e070>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
Wed Aug 03 02:12:53 IST 2022 - ERROR - Failed to get package and modules details.
Wed Aug 03 02:12:53 IST 2022 - ERROR - Failed to send telemetry report to LanternRock cannot import name 'LanternRock' from 'lanternrock' (unknown location)
Wed Aug 03 02:12:54 IST 2022 - INFO - Sending installation report
Wed Aug 03 02:12:54 IST 2022 - ERROR - Failed to connect. Please check the Internet connection and proxy settings and retry. HTTPSConnectionPool(host='edgesoftwarehub.intel.com', port=443): Max retries exceeded with url: /analytics (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8d51b5e0a0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
Wed Aug 03 02:12:54 IST 2022 - INFO - Installation of package complete
JesusE_Intel
Hi MohammedSaif,
Are you okay with closing this discussion too as you have a working reference implementation per our other discussion?
Solved: Docker configuration manager agent did not finish provisioning in time - Intel Communities
By the way, the original error in this discussion was due to the user not having the correct docker permissions. I ran into the same error and resolved by running the following commands:
groupadd docker
usermod -a -G docker $USER
reboot
Jesus
JesusE_Intel
Hi MohammedSaif,
I am also seeing the same error on a fresh Ubuntu 20.04 system. I have escalated the issue to development team for further investigation. I will let you know what I find out.
Jesus
MohammedSaif
Hey Jesus,
So i decided to reinstall ubuntu 20.04 LTS. I am now getting the above error during the installation of Automated License Plate Recognition. Did you get a reply back from the dev team?
SShan_Intel
Hi MohammedSaif,
Could you try to install with sudo? sudo ./edgesoftware install
SShan
MohammedSaif
Hey Sshan, thanks for your reply. I was able to resolve that error. The next issue i am facing is with the make webui command. After the installation, when i runthe below command, it gives me a makefile error.
saif@saif-Latitude-7520:~/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase$ make webui EII_BASE= Desktop/LPR/Automated_License_Plate_Recognition_2022.1/IEdgeInsights REPO_FOLDER= Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
fatal: not a git repository (or any of the parent directories): .git
xhost +
access control disabled, clients can connect from any host
# Activate virtual env and Launch WebUI
cd src/webui && source /".uc_virtual_env"/bin/activate && python3 ./server.py
/bin/bash: /.uc_virtual_env/bin/activate: No such file or directory
make: *** [Makefile:101: webui] Error 1
Any pointers on what could be the problem here?
SShan_Intel
Hi MohammedSaif,
You are missing / in front of Desktop:
make webui EII_BASE=/Desktop/LPR/Automated_License_Plate_Recognition_2022.1/IEdgeInsights REPO_FOLDER= /Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
SShan
MohammedSaif
Hi Sshan, tried that. Here's the output
saif@saif-Latitude-7520:~/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase$ make webui EII_BASE=/Desktop/LPR/Automated_License_Plate_Recognition_2022.1/IEdgeInsights REPO_FOLDER= /Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
xhost +
SShan_Intel
Hi MohammedSaif,
Based on the error, it says the path is not exist. Could you verify it ? make sure you are in directory:
cd /Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
Then check if this file exist from your end.
$ ls -ld .uc_virtual_env/bin/activate
-rw-r--r-- 1 intel intel 2359 Ogos 5 16:41 .uc_virtual_env/bin/activate
The file should be installed during package installation.
SShan
MohammedSaif
Hi Sshan,
Yes i can confirm that i am in that directory. Also ran the command you mentioned in the same directory. Here's the output:
saif@saif-Latitude-7520:~/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase$ ls -ld .uc_virtual_env/bin/activate
-rw-r--r-- 1 saif saif 2370 Aug 10 16:12 .uc_virtual_env/bin/activate
SShan_Intel
Hi Saif,
I just notice that the make gui command you are missing a folder name. Could you try if it work? I tested from my end, i dont have issue running make webui command.
saif@saif-Latitude-7520:~/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase$ make webui EII_BASE=/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/IEdgeInsights REPO_FOLDER= /Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
SShan
MohammedSaif
Hi SShan, tried that. Still the same error as above
JesusE_Intel
Hi MohammedSaif,
groupadd docker
reboot
Jesus
MohammedSaif
Hi Jesus,
Thank you for providing a solution to the original error and please accept my apologies for the delay in my reply. And yes, I am okay with closing this discussion.
Saif
JesusE_Intel
