Intel® Edge Software Hub
Get help on building Edge Software Hub solutions for edge compute node
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
317 Discussions
ESDQ 6.0 vision on Tiger lake platform
AmandaLee
Dear Sir,
We run ESDQ 6.0 Vision on tiger lake platform and there are some failed items.
1. AWS install failed.
AWS failAWS fail
2. MSDK5 test failed
MSDK5 failMSDK5 fail
Could you have some suggestion for it?
$ ./esdq systeminfo
Executing System Info
SysInfo collection initiated
Calling system info execution
Started executing individual info collection
[ SOFTWARE INFO ]
OS version: Ubuntu 20.04.2 LTS
Kernel: 5.13.0-30-generic
[ HARDWARE INFO ]
Device Manufacturer: Avalue
Hardware Architecture: x86_64
Processor: 11th Gen Intel(R) Core(TM) i7-1185G7E @ 2.80GHz
GPU Name: Intel Corporation
Memory size: 15Gi
[ HARDWARE ACCELERATOR ]
No hardware accelerator found
Amanda
Xiang_Intel
Hi Amanda,
For the mediasdk_sample_encode_with_h265, may I know if you have tried the following steps in the documentation?
Media sdk sample encode test failed with the message:
“ERROR], sts=MFX_ERR_UNSUPPORTED(-3),…"
Follow the steps below as a possible solution:
sudo apt install --reinstall linux-firmware
Add i915.enable_guc=2  in /etc/default/grub: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i915.force_probe=* i915.enable_guc=2"
sudo update-initramfs –u
sudo update-grub
Reboot the system.
After reboot, execute the command:  dmesg | grep guc
Verify the logs for guc information. If output doesn't contain guc details, then get the latest guc/huc firmware. Copy the firmware to /lib/firmware/i915/, and reboot the system.
Thanks and regards,
Lim Xiang Yang
Xiang_Intel
Hi Amanda,
sudo update-grub
Reboot the system.
Thanks and regards,
Lim Xiang Yang
Xiang_Intel
Hi Amanda,
There is a new version for ESDQ for Vision rolled out as a hotfix for the issues that you have faced. Can you give it a try and let me know if these issues still persist?
You can find it at the link below,
ESDQ 6.1: https://software.intel.com/iot/edgesoftwarehub/download/home/esdq_vision
Documentation:  https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualificat...
Thanks and regards,
Lim Xiang Yang
AmandaLee
Hi Lim Xiang Yang,
These two issues are resolved after modifying grub file and using ESDQ6.1.
Thanks for your assistance.
Amanda
JesusE_Intel
