Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
340 Discussions
ESDQ 6.1 on ElKhart Lake Platform can not run (Vision test module fail)
Eke
Hi Sir:
we hope to validate Elkhart Lake with Vision ESDQ .
Issue Description :
The final report data (esdqReport_2022-05-18_03_46.zip) does no shows the test result output of “ Vision test module ”.
So far we test mix ESDQ 5.0 and 6.1 componet module, but still fail and many times .
1. The new 6.1 Vision module can't download ?
<project path="installation/src" id="621692878bad76002bce2ee8" version="2021.4.1" label="esdq/Vision_Test_Module"/>
Downloading component esdq/Vision_Test_Module
Failed to download the module esdq/Vision_Test_Module. 404 Not Found
2.So we used old vision test module
<project id="6216928e8bad76002bce2ef4" label="esdq/Vision_Test_Module" path="installation/src" version="2021.4.1" />
for the testing with HDDL problem i had been Add following entry in $HDDL_INSTALL_DIR/config/hddl_service.config like this:
"service_settings":
"autoboot_boot_timeout_sec": 10,
that still fail .
| Test Module | Version | ID |
| Vision_Test_Module | 2021.4.1 | 6216928e8bad76002bce2ef4 |
| VATS_Test_Module | 2021.4 | 60f084f3acbb0a002bcaee71 |
Summary
Property
Value
0
ESDQ Version
6.0
1
Execution Timestamp UTC
2022-05-18 03:44:41
2
Duration
0:01:38
3
Number of test category
3
4
Test Categories
'SysInfo' 'Vision_Test_Module' 'VATS_Test_Module'
SystemInfo
System Category
Property
Value
0
SOFTWARE INFO
OS version
Ubuntu 20.04.4 LTS
1
SOFTWARE INFO
Kernel
5.13.0-41-generic
2
HARDWARE INFO
Device Manufacturer
Neousys Technology Inc.
3
HARDWARE INFO
Hardware Architecture
x86_64
4
HARDWARE INFO
Processor
Intel Atom(R) x6425E Processor @ 2.00GHz
5
HARDWARE INFO
GPU
Intel Corporation
6
HARDWARE INFO
Memory size
15Gi
7
HDD Configurations
Model
ATA INTEL SSDSCKKR12 (scsi)
8
HDD Configurations
Disk /dev/sda
120GB
9
HDD Configurations
Sector size (logical/physical)
512B/512B
10
HDD Configurations
Partition Table
gpt
11
HDD Configurations
Disk Flags Header
Number Start End Size File system Name Flags
12
HDD Configurations
Disk Flags
1 1049kB 538MB 537MB fat32 EFI System Partition boot esp
13
HDD Configurations
Disk Flags
2 538MB 120GB 119GB ext4
14
HARDWARE ACCELERATOR
VPU
0
15
FPGA
0
ModulesInfo
Installed Module
Status
0
K3s_Lightweight_Kubernetes
SUCCESS
1
Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_Runtime
SUCCESS
2
Intel_Deep_Learning_Streamer
SUCCESS
3
Docker_Community_Edition_CE
SUCCESS
4
Intel_Distribution_of_OpenVINO_toolkit_2021_4_2_in_a_Container
SUCCESS
5
Docker_Compose
SUCCESS
6
Edgex_Foundry
SUCCESS
7
RI_MultiCamera_Social_Distancing
SUCCESS
8
esdq
SUCCESS
Test Suites
Vision_Test_Module
ModuleName
Test CaseName
SampleProgram
Status
VATS_Test_Module
Missing report !
JesusE_Intel
Hi Eric,
The development team has addressed this issue. I tested from my end and can confirm the test modules are now displaying in the report. Could you please re-download the ESDQ package and test on your side? Please let me know if you have any issues.
Jesus
JesusE_Intel
Hi Eke,
Thanks for reporting, I was able to reproduce the issue and have reached out to the development team. I will let you know what I find out.
Jesus
Eke
Hi Jesus,
Thanks for support, I will be waitting for your further good news!
Eric Ke
JesusE_Intel
Hi Eric,
Jesus
JesusE_Intel
