Intel® Edge Software Hub
Get help on building Edge Software Hub solutions for edge compute node
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
317 Discussions
ESDQ Aibox : Vehicle_Attribute_Pipeline_CPU/GPU are null.
AmandaLee
Hi expert,
I have installed and run the Intel ESDQ for Aibox on a target system (i7-9700E).
After the procedure, the average throughput value of Vehicle_Attribute_Pipeline_CPU/GPU are null.
The attached file is the test report.
Could you please provide your suggestion about it?
Amanda
JesusE_Intel
Hi Amanda,
The package has been fixed and updated.
Could you please try to re-download the package and let me know if you run into any issues?
Jesus
JesusE_Intel
Hi AmandaLee,
Thank you for reporting this issue, I was able to reproduce it from my end. Please allow me to look into it and get back to you.
Jesus
JesusE_Intel
Hi Amanda,
Looks like there are some issues with DLStreamer, I have escalated this issue to the development team for further investication. I will give you another update once I hear back.
Jesus
AmandaLee
Hi Jesus,
Thanks for the update on the issue. I look forward to hearing from you.
Amanda
JesusE_Intel
Hi Amanda,
Jesus
AmandaLee
Hi Jesus,
I still get some error when I try "ESDQ for AiBox 2.5 deployment".
Please kindly find the attached report for more message.
Thanks & Regards,
Amanda
JesusE_Intel
Hi Amanda,
I took a look at this esdq report you provided; this system appears to be different from your original post. Do you have access to the original system? Just want to confirm the original issue is fixed for you. I just tested on a system with 9th generation processor, and everything passed.
The new system shows that some tests for aibox_metrics failed. Looking closer at the logs, there may have been an internet issue as an OpenVINO model was not downloaded which caused the GStreamer pipeline to fail. Could you check your internet/proxy settings and try again?
AI Box collecting metrics ... with the log process id information:
60600
60602
----Starting benchmark docker commands -------
Executing pipeline setup environment...
./pipeLine_setup.sh: line 6: omz_downloader: command not found
 % Total  % Received % Xferd Average Speed  Time  Time   Time Current
                 Dload Upload  Total  Spent  Left Speed
 0   0  0   0  0   0   0   0 --:--:-- --:--:-- --:--:--   0
 0   0  0   0  0   0   0   0 --:--:-- --:--:-- --:--:--   0Warning: Failed to create the file
Warning: share/models/intel/person-vehicle-bike-detection-2004/person-vehicle-b
Warning: ike-detection-2004.json: No such file or directory
100  209 100  209  0   0  419   0 --:--:-- --:--:-- --:--:--  418
curl: (23) Failed writing body (0 != 209)
./pipeLine_setup.sh: line 13: omz_downloader: command not found
Warning: share/models/intel/vehicle-attributes-recognition-barrier-0039/vehicle
Warning: -attributes-recognition-barrier-0039.json: No such file or directory
100  565 100  565  0   0  1101   0 --:--:-- --:--:-- --:--:-- 1101
curl: (23) Failed writing body (0 != 565)
 0   0  0   0  0   0   0   0 --:--:-- 0:00:01 --:--:--   0
100 2745k 100 2745k  0   0 1476k   0 0:00:01 0:00:01 --:--:-- 3218k
pipeline setup environment is completed.
 Running vehicle attribute tests ...
 executing vehicle attribute pipeline test with device option as CPU ....
rm: cannot remove '*.mp4': No such file or directory
ERROR: from element /GstPipeline:pipeline0/GstGvaClassify:gvaclassify3: 'model' does not exist
Additional debug info:
/root/gst-video-analytics/gst/inference_elements/base/gva_base_inference.cpp(788): gva_base_inference_check_properties_correctness (): /GstPipeline:pipeline0/GstGvaClassify:gvaclassify3:
path share/models/intel/vehicle-attributes-recognition-barrier-0039/FP16-INT8/vehicle-attributes-recognition-barrier-0039.xml set in 'model' does not exist
ERROR: pipeline doesn't want to preroll.
Jesus
AmandaLee
Hi Jesus,
I suppose my network is stable, but i will try it again.
For original post, let me find out the device i used before and show you the result later.
Thanks & Regards,
Amanda
JesusE_Intel
Thank you Amanda, here is the hardware info from the original esdqReport on 10/18/2022.
Tue Oct 18 12:10:36 IST 2022 - INFO - [ HARDWARE INFO ]
Tue Oct 18 12:10:41 IST 2022 - INFO - Device Manufacturer: ONYX Healthcare Inc
Tue Oct 18 12:10:41 IST 2022 - INFO - Hardware Architecture: x86_64
Tue Oct 18 12:10:41 IST 2022 - INFO - Processor: Intel(R) Core(TM) i7-9700E CPU @ 2.60GHz
Tue Oct 18 12:10:42 IST 2022 - INFO - GPU Name: UHD Graphics 630 (Desktop 9 Series)
Tue Oct 18 12:10:42 IST 2022 - INFO - Memory size: 15Gi
Jesus
JesusE_Intel
Hi Amanda,
I will proceed to close this discussion. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jesus
AmandaLee
Hi Jesus,
I can't find the original device for clarify it.
But I have try the new "ESDQ for Aibox" on another devie, and all items are pass.
Many thanks for your assistance. ^^
Amanda
