Hi Sir:
we had been certification with ESDQ-ECI , but when we build up the kernel with SOP and that had some difference with BKC and test started .
did you have any comment for this ? thanks !
could you elaborate further the differences that you mentioned.
I assume your setup fulfilled the Target System Requirements?
Cordially,
Iffa
Hi Iffa :
below is the key difference . PLS let us know if still any comment for this , TKS!
Module Name | Test Case | Result | BKC | Color |
RTPM_CONFIGURATION_CHECK | CPU_FAMILY_CHECK | 13th Gen Intel(R) Core(TM) i5-13500E | NA | #ffffff |
RTPM_PREEMPT_RT_BOOTCMDLINE_CHECK | CHECK CMDLINE PARAM: nohalt | Missing | nohalt | #ffff00 |
RTPM_PREEMPT_RT_BOOTCMDLINE_CHECK | CHECK CMDLINE PARAM: nohz | Missing | nohz | #ffff00 |
RTPM_PREEMPT_RT_BOOTCMDLINE_CHECK | CHECK CMDLINE PARAM: cpufreq.off | Missing | 1 | #ffff00 |
RTPM_PREEMPT_RT_BOOTCMDLINE_CHECK | CHECK CMDLINE PARAM: nowatchdog | Missing | nowatchdog | #ffff00 |
RTPM_PREEMPT_RT_KERNEL_CHECK | CHECK KERNEL CONFIG: CONFIG_SCHED_MC_PRIO | CONFIG_SCHED_MC_PRIO=y | CONFIG_SCHED_MC_PRIO=n | #ffff00 |
RTPM_PREEMPT_RT_KERNEL_CHECK | CHECK KERNEL CONFIG: CONFIG_CPU_FREQ | CONFIG_CPU_FREQ=y | CONFIG_CPU_FREQ=n | #ffff00 |
In order for us to investigate further, could you share:
- Your installed ECI and kernel, which ECI version you are using? Please share the output of: uname -a
- To clarify your question, did you run ESDQ using standard ECI kernel (without modification) and see some missing/failing modules?
- Does the previous certification obtained using the same hardware/software versions?
Cordially,
Iffa
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
