Intel® Edge Software Hub
Get help on building Edge Software Hub solutions for edge compute node
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
318 Discussions
ESDQ for AMR Errors - RealSense relative
huang__shiuan-chi
We have run the ESDQ test on our device, connected with Intel RealSense D435.
We failed in the test modules AMR7 and AMR10, which are RealSense and GStreamer RealSense.
It seems the ESDQ process didn't receive data from RealSense, but we don't know the reason.
Attach the Log file for reference. Please help us figure out how to pass the RealSense relative test module, thank you.
Sahira_Intel
Thank you for confirming. Yes, it is required to use a D435i when running ESDQ for AMR since it requires use of the inertial measurement unit (IMU) which the D435 does not have.
Sincerely,
Sahira
Sahira_Intel
Your log files say that a RealSense L515 was detected:
RealSense ROS version and RGB Camera info were found
RealSense L515 camera connected.
Can you please confirm what RealSense device you are using?
Sincerely,
Sahira
huang__shiuan-chi
We have confirmed that we are using D435, Here's the capture of lsusb:
Bus 004 Device 003: ID 8086:0b07 Intel Corp. Intel(R) RealSense(TM) Depth Camera 435
I don't know why it shows L515. The testLogs.log also shows that
[INFO] [1646633440.706940328] [RealSenseCameraNode]: Device with name Intel RealSense D435 was found.
According to the documents
https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualification-amr.html
the System Requirements is Intel® RealSense™ camera D435i
Is it fine that we are using the Realsense camera D435 without "I"?
Sahira_Intel
Sincerely,
Sahira
