Hi @Iffa_Intel
While trying to install the ESDQ (Intel_Edge_AI_Box_4.0).We are getting an error at the "aibox-dlstreamer" docker image building stage .
Error:
The following packages have unmet dependencies:
intel-dlstreamer-gst-plugins-base : Depends: liborc-0.4-dev-bin:any (= 1:0.4.32-2)
Tried multiple times from the scratch (Fresh Installation of Ubuntu-22.04).But no luck getting same issue
Attached is the screen shot with the exact error and details pertaining to it.
Appreciate your timely and a quick help in having this resolved.
ITO - XactAI.
Could you clarify:
1. Are you following the steps from this official guide?
2. Are you attempting to install the Intel_Edge_AI_Box_4.0 in a Docker environment? (could you share steps that you did to setup your Docker?)
3. Are you using any proxy?
4. Have you tried to run the installation using different network connection?
Cordially,
Iffa
Hi @Iffa_Intel
Thanks for your Quick Response.
Yes, I'm following the steps and instructions from the official guide.
No, I'm not using any other instructions other than from the official guide. Below are the commands that I followed
unzip intel_edge_ai_box.zip
cd intel_edge_ai_box
chmod 755 edgesoftware
./edgesoftware install
Then it started some process like running the Dockerfile's to create a Docker images
No
Not yet, I will try with different network and give an update in this thread.
Thanks & Regards,
ITO - XactAI.
Hi @Iffa_Intel
I was tried with different network to install the Intel_Edge_AI_Box_4.0.But no luck still getting the same dependency error.Please check the below attached screenshot.Could you please help us to solve this issue
Thanks & Regards,
ITO - XactAI.
Thank you for trying.
We'll further investigate this.
Cordially,
Iffa
Hi @Iffa_Intel
Sorry for the late reply and Thanks for your Quick response
I was tried in multiple ubuntu-22.04 versions like 22.04.3 & 22.04.4.Still no luck getting the same dependency error.
Here is the system configuration which i tried to install the ESDQ.
Thanks & Regards,
ITO - XactAI.
Hi Iffa,
Is there any update on this issue? I'm facing the same problem.
Thanks & Regards,
Amanda
The problem has been resolved.
It only requires reinstalling the package, better in a clean environment.
Amanda
Hi @AmandaLee
Happy to hear that you resolved the issue.
I already reinstalled the packages multiple times within the new ubuntu-22.04 environment.But still its not resolved
Could you please elaborate the steps you followed to resolve this issue.
Thanks & Regards,
ITO - XactAI.
Hi @ito_xactai ,
I followed all the steps in the link , including setting system locales, and it's working.
sudo apt-get install locales -y
sudo locale-gen en_US.UTF-8
sudo update-locale LANG=en_US.UTF-8 LC_CTYPE=en_US.UTF-8 LC_IDENTIFICATION=en_US.UTF-8
sudo reboot
BTW, I have re-downloaded the Aibox ESDQ package.
Amanda
Thanks for the reply @AmandaLee
I will check and let you know the status.
Thanks & Regards,
ITO - XactAI.
Glad to know that your issues have been resolved.
In case any installation issues persist, please help to use the new Edge software package on a fresh Ubuntu 22.04.
You may refer to this Edge AI Box Software Catalog.
Cordially,
Iffa
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
