Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
Edge Insigts for Vision
PhaniMVS
Very nice morning sir.
I am trying to install OpenVinoInsights package.
I am getting the error on gstreamer package.
Is the install package corrupt or am i missing install dependencies.
Attached the trace of the installation.
Please advice.
Phani
ERROR: Failed to install: intel-openvino-runtime-ubuntu20-2021.4.582
Failed command: sudo apt install -y intel-openvino-runtime-ubuntu20-2021.4.582
Failed to install Intel_Distribution_of_OpenVINO_toolkit_2021_4_Runtime took 12.79 seconds
Installing Deep_Learning_Streamer_Pipelines
Dependency check failed during DL Streamer. OpenVINO is not installed
ERROR: Failed to install: OpenVINO
Failed to install Deep_Learning_Streamer_Pipelines took 0.00 seconds
Installing Docker_Community_Edition_CE
Verifying if docker is installed [..................................................] 100%
Successfully installed Docker CE
Successfully installed Docker_Community_Edition_CE took 11.76 seconds
Installing Intel_Distribution_of_OpenVINO_toolkit_2021_4_in_a _Container
Stopping OpenVINO Containers [..................................................] 100%
Building Docker image. This step may take approximately 5 mins.
Building docker image [..................................................] 100%
Successfully installed Intel_Distribution_of_OpenVINO_toolkit_2021_4_in_a _Container took 36.25 seconds
Installing Docker_Compose
Verifying Docker [..................................................] 100%
Installing Docker Compose [..................................................] 100%
Successfully installed docker-compose
Successfully installed Docker_Compose took 7.70 seconds
Installing Edgex_Foundry
Installing EdgeX [ ] 0%Installing EdgeX. This step may take approximately 5 mins.
Installing EdgeX [..................................................] 100%
Checking Edgex Installation [..................................................] 100%
Successfully installed Edgex_Foundry took 23.06 seconds
Installing RI_MultiCamera_Social_Distancing
Installing Multi-Camera dependencies. This step may take upto 20 mins.
Installing Multi-Camera dependencies [.................... ] 40% 00:00:22OK
Installing Multi-Camera dependencies [......................... ] 50% 00:00:18deb https://repos.influxdata.com/ubuntu focal stable
ERROR: Failed to install Influxdb
Failed command: sudo apt-get install influxdb -y
Failed to install RI_MultiCamera_Social_Distancing took 18.84 seconds
Installation of package complete
| Id | Module | Status |
| 6021bb103cb8eb002ac47d71 | Amazon Web Services Greengrass Prerequisites | SUCCESS |
| 60e58b534c1e9d002a6d6b1f | K3s Lightweight Kubernetes | SUCCESS |
| 60e07fd84c1e9d002a6d6a17 | Intel Distribution of OpenVINO toolkit 2021 4 Runtime | FAILED |
| 60e58cef4c1e9d002a6d6b24 | Deep Learning Streamer Pipelines | FAILED |
| 605cab935a4b53002c272678 | Docker Community Edition CE | SUCCESS |
| 60e58ec64c1e9d002a6d6b27 | Intel Distribution of OpenVINO toolkit 2021 4 in a Container | SUCCESS |
| 60e58fca4c1e9d002a6d6b2a | Docker Compose | SUCCESS |
| 60e58f414c1e9d002a6d6b29 | Edgex Foundry | SUCCESS |
| 60ebf6b43a57ff002a8f8842 | RI MultiCamera Social Distancing | FAILED |
ubuntu@ip-172-31-46-141:~/Desktop/OpenVino/edge_insights_vision$ sudo apt install -y intel-openvino-runtime-ubuntu20-2021.4.582
Reading package lists... Done
Building dependency tree
Reading state information... Done
intel-openvino-runtime-ubuntu20-2021.4.582 is already the newest version (2021.4-582).
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
intel-openvino-runtime-ubuntu20-2021.4.582 : Depends: intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582 (= 2021.4-582) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
ubuntu@ip-172-31-46-141:~/Desktop/OpenVino/edge_insights_vision$ sudo apt-get install intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 59 not upgraded.
15 not fully installed or removed.
Need to get 0 B/2475 kB of archives.
After this operation, 0 B of additional disk space will be used.
E: Invalid archive member header
E: Prior errors apply to /var/cache/apt/archives/intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582_2021.4-582_amd64.deb
debconf: apt-extracttemplates failed: No such file or directory
(Reading database ... 196333 files and directories currently installed.)
Preparing to unpack .../intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582_2021.4-582_amd64.deb ...
Unpacking intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582:amd64 (2021.4-582) ...
dpkg-deb (subprocess): cannot copy archive member from '/var/cache/apt/archives/intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582_2021.4-582_amd64.deb' to decompressor pipe: unexpected end of file or stream
dpkg-deb (subprocess): decompressing archive member: lzma error: unexpected end of input
dpkg-deb: error: <decompress> subprocess returned error exit status 2
dpkg: error processing archive /var/cache/apt/archives/intel-openvino-gstreamer-rt-ubuntu-focal-2021.4.582_2021.4-582_amd64.deb (--unpack):
cannot copy extracted data for './opt/intel/openvino_2021.4.582/data_processing/gstreamer/lib/gstreamer-1.0/libgstgoom.so' to '/opt/intel/openvino_2021.4.582/data_processing/gstreamer/lib/gstreamer-1.0/libgstgoom.so.dpkg-new': unexpected end of file or stream
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
JesusE_Intel
Hi PhaniMVS,
Thanks for reaching out, I just tested the Intel Edge Insights for Vision software package on a fresh Ubuntu 20.04 system. I didn't see any errors during the installation using the latest 2021.4 release.
  • Does your system have a fresh installation of Ubuntu?
  • What Ubuntu version and kernel version are you using?
  • What version of the software package are you using?
Could you provide the content of output.log? The log file is located at the following directory:
/var/log/esb-cli/Edge_Insights_for_Vision_<version>
Jesus
JesusE_Intel
