Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
434 Discussions
Edge Software Hub driver management docker-build failed on open_model_zoo folder not found
Lin__Joey
Innovator
Dear expert,
As title, Error message attached below,
root@joeylinSER0:/home/joeylin/Downloads/driver_management/Driver_Management_2020.3/Driver_Management/OpenVino-Driver-Management# sudo make docker-build
---> c7e4487d3c61
Step 33/45 : RUN if [ ! -d "/opt/intel/openvino/deployment_tools/open_model_zoo" ]; then git clone https://github.com/opencv/open_model_zoo.git; cd /opt/intel/openvino/deployment_tools/open_model_zoo; git checkout 2020.3; fi
---> Running in e2445cda5871
+ '[' '!' -d /opt/intel/openvino/deployment_tools/open_model_zoo ']'
+ git clone https://github.com/opencv/open_model_zoo.git
Cloning into 'open_model_zoo'...
error: RPC failed; curl 56 GnuTLS recv error (-54): Error in the pull function.
fatal: The remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
+ cd /opt/intel/openvino/deployment_tools/open_model_zoo
/bin/bash: line 0: cd: /opt/intel/openvino/deployment_tools/open_model_zoo: No such file or directory
+ git checkout 2020.3
fatal: not a git repository (or any of the parent directories): .git
The command '/bin/bash -xo pipefail -c if [ ! -d "/opt/intel/openvino/deployment_tools/open_model_zoo" ]; then git clone https://github.com/opencv/open_model_zoo.git; cd /opt/intel/openvino/deployment_tools/open_model_zoo; git checkout 2020.3; fi' returned a non-zero code: 128
Makefile:2: recipe for target 'docker-build' failed
make: *** [docker-build] Error 128
Joey Lin
JesusE_Intel
Hi Joey,
This may be a temporary network issue, I just build the docker images without any issues. Any chance you are behind a firewall? Try the steps in the troubleshooting section of the installation guide and let me know if that helps.
Jesus
JesusE_Intel
Hi Joey,
Jesus
Lin__Joey
Innovator
Hi Jesus,
Thank you for your confirmation. I tried again this morning, and it worked this time.
Have a good day,
Joey Lin
JesusE_Intel
Thank you for confirming! If you need any additional information, please submit a new question as this thread will no longer be monitored.
