Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
413 Discussions
Edge insight software installation Failing
Rajnish
I am getting following error while installing Eis:-
Failed to provision secrets to vault...!!
PFA
Request for earlier help.
Murni_J_Intel
Hi @Rajnish
I will look into this issue and get back to you as soon as possible. May I know if this is a fresh system or the previous version has been installed here before?
Murni_J_Intel
Hi @Rajnish
The issue seems like you are having a different version of PyYAML from the requirement. It should use PyYAML version  PyYAML-5.1.1.  You can uninstall the existing version manually and install the PyYAML version-5.1.1 as per below command
pip3 install PyYAML==5.1.1
 After doing the above installation, you can re-run again the ./edgesoftware install command.
Rajnish
Thank you so much...!!
Issue is resolve now.
