Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
Edgesoftware ONNX build fail
premp
I am using Intel® Edge Software Device Qualification (ESDQ) to generate report for hardware.
After running "./edgeSoftware install" command all the modules are build successful and ONNX build is getting failed with below errors:
Error:Failed to build onnxruntime
Failed command:./build.sh --config RelWithDebInfo --use_openvino CPU_FP32 --build --update --build_wheel  --parallel
Failed to install ONNX_Runtime took 9 minutes 20.14 seconds
Configuration used to run:
OS: Ubuntu 20.4.2
RAM: 16GB
Python: 3.8.2
JesusE_Intel
Hi premp,
Is this a fresh Ubuntu 20.04 system? Could you provide the following log files?
/var/log/esb-cli/Edge_Software_Device_Qualification_3.0/output.log
/var/log/esb-cli/Edge_Software_Device_Qualification_3.0/esdq/install.log
Jesus
premp
HI Jesus,
I have the logs for the installation I tried on Ubuntu 18.04 where I faced the same issue of ONNX Build failed. Please find both logs below.
Wed Aug 11 01:04:19 IST 2021 - INFO - ESB CLI version: 2021.1
Target OS: Ubuntu 18.04
Wed Aug 11 01:04:20 IST 2021 - INFO - Python version: 3.6.9
Wed Aug 11 01:04:20 IST 2021 - INFO - Checking Internet connection
Wed Aug 11 01:04:20 IST 2021 - INFO - Connected to the Internet
Wed Aug 11 01:04:20 IST 2021 - INFO - Validating product key
Wed Aug 11 01:04:21 IST 2021 - INFO - Successfully validated Product Key
Wed Aug 11 01:04:21 IST 2021 - INFO - Connected to a network in United States
Wed Aug 11 01:04:21 IST 2021 - INFO - Checking for prerequisites
Wed Aug 11 01:04:25 IST 2021 - INFO - Installing prerequisites. This may take some time...
Wed Aug 11 01:05:04 IST 2021 - INFO - --------Succesfuly installed prerequisites--------
Wed Aug 11 01:05:04 IST 2021 - INFO - All dependencies met
Wed Aug 11 01:05:05 IST 2021 - INFO - -------------------SYSTEM INFO--------------------
Wed Aug 11 01:05:05 IST 2021 - INFO - Package Name: Edge Software Device Qualification 3.0
Wed Aug 11 01:05:05 IST 2021 - INFO - Product Name: <Product Name>
Wed Aug 11 01:05:05 IST 2021 - INFO - CPU SKU: Intel(R) Xeon(R) Gold 6330 CPU @ 2.00GHz
Wed Aug 11 01:05:05 IST 2021 - INFO - Memory Size: 15 GB
Wed Aug 11 01:05:05 IST 2021 - INFO - Operating System: Ubuntu 18.04.5 LTS
Wed Aug 11 01:05:05 IST 2021 - INFO - Kernel Version: 5.4.0-80-generic
Wed Aug 11 01:05:05 IST 2021 - INFO - Accelerator: None
Wed Aug 11 01:05:05 IST 2021 - INFO - CPU Utilization: 0.6%
Wed Aug 11 01:05:05 IST 2021 - INFO - Available System Memory: 408 GB
Wed Aug 11 01:05:06 IST 2021 - INFO - Starting installation
Wed Aug 11 01:05:06 IST 2021 - INFO - Modules to be downloaded by package are ['esb_common', 'Amazon_Web_Services_Greengrass_Prerequisites', 'K3s_Lightweight_Kubernetes', 'Azure_IoT_Edge_Prerequisites', 'Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime', 'Deep_Learning_DL_Streamer_Pipelines', 'Docker_Community_Edition_CE', 'Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container', 'Docker_Compose', 'edgex_foundry', 'ONNX_Runtime', 'RI_MultiCamera_Social_Distancing', 'Connect_Edge_Devices_to_Azure_IoT', 'esdq/Vision_Test_Module', 'esdq', 'esdq/VATS_Test_Module']
Wed Aug 11 01:05:06 IST 2021 - INFO - Downloading modules...
Wed Aug 11 01:05:06 IST 2021 - INFO - Downloading component esb_common
Wed Aug 11 01:05:06 IST 2021 - INFO - Sending request to download module 5e8c4742e02f17002a2a6976
Wed Aug 11 01:05:08 IST 2021 - INFO - Sending request to validate module 5e8c4742e02f17002a2a6976 with hash value 6914ceadfd836157c6642d761c7c47f7
Wed Aug 11 01:05:08 IST 2021 - INFO - Module validation passed for 5e8c4742e02f17002a2a6976
Wed Aug 11 01:05:08 IST 2021 - INFO - Successfully downloaded module esb_common
Wed Aug 11 01:05:08 IST 2021 - INFO - Downloading component Amazon_Web_Services_Greengrass_Prerequisites
Wed Aug 11 01:05:08 IST 2021 - INFO - Sending request to download module 601c2f303eb151002ace2c3b
Wed Aug 11 01:05:09 IST 2021 - INFO - Sending request to validate module 601c2f303eb151002ace2c3b with hash value 24d580ce9e4a97fa3e813c0447a2cb34
Wed Aug 11 01:05:10 IST 2021 - INFO - Module validation passed for 601c2f303eb151002ace2c3b
Wed Aug 11 01:05:10 IST 2021 - INFO - Successfully downloaded module Amazon_Web_Services_Greengrass_Prerequisites
Wed Aug 11 01:05:10 IST 2021 - INFO - Downloading component K3s_Lightweight_Kubernetes
Wed Aug 11 01:05:10 IST 2021 - INFO - Sending request to download module 605c61985a4b53002c27263b
Wed Aug 11 01:05:11 IST 2021 - INFO - Sending request to validate module 605c61985a4b53002c27263b with hash value 9252909dec0a3cdbb4999098902df7ab
Wed Aug 11 01:05:11 IST 2021 - INFO - Module validation passed for 605c61985a4b53002c27263b
Wed Aug 11 01:05:11 IST 2021 - INFO - Successfully downloaded module K3s_Lightweight_Kubernetes
Wed Aug 11 01:05:11 IST 2021 - INFO - Downloading component Azure_IoT_Edge_Prerequisites
Wed Aug 11 01:05:11 IST 2021 - INFO - Sending request to download module 5fff12aa54e210002a5f52b4
Wed Aug 11 01:05:14 IST 2021 - INFO - Sending request to validate module 5fff12aa54e210002a5f52b4 with hash value 30f8e489a24ec7f73052097db9850c79
Wed Aug 11 01:05:15 IST 2021 - INFO - Module validation passed for 5fff12aa54e210002a5f52b4
Wed Aug 11 01:05:15 IST 2021 - INFO - Successfully downloaded module Azure_IoT_Edge_Prerequisites
Wed Aug 11 01:05:15 IST 2021 - INFO - Downloading component Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime
Wed Aug 11 01:05:15 IST 2021 - INFO - Sending request to download module 605c63865a4b53002c27263c
Wed Aug 11 01:05:17 IST 2021 - INFO - Sending request to validate module 605c63865a4b53002c27263c with hash value 86d81835816500162493398299555f52
Wed Aug 11 01:05:17 IST 2021 - INFO - Module validation passed for 605c63865a4b53002c27263c
Wed Aug 11 01:05:17 IST 2021 - INFO - Successfully downloaded module Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime
Wed Aug 11 01:05:17 IST 2021 - INFO - Downloading component Deep_Learning_DL_Streamer_Pipelines
Wed Aug 11 01:05:17 IST 2021 - INFO - Sending request to download module 605c656c5a4b53002c27263f
Wed Aug 11 01:05:19 IST 2021 - INFO - Sending request to validate module 605c656c5a4b53002c27263f with hash value 16fde3148e2228668edc2978af5714f5
Wed Aug 11 01:05:20 IST 2021 - INFO - Module validation passed for 605c656c5a4b53002c27263f
Wed Aug 11 01:05:20 IST 2021 - INFO - Successfully downloaded module Deep_Learning_DL_Streamer_Pipelines
Wed Aug 11 01:05:20 IST 2021 - INFO - Downloading component Docker_Community_Edition_CE
Wed Aug 11 01:05:20 IST 2021 - INFO - Sending request to download module 5f21392e9e63c9002a6fd88d
Wed Aug 11 01:05:21 IST 2021 - INFO - Sending request to validate module 5f21392e9e63c9002a6fd88d with hash value 27f50c91517b3b6bb8d27d43aaa5d25f
Wed Aug 11 01:05:21 IST 2021 - INFO - Module validation passed for 5f21392e9e63c9002a6fd88d
Wed Aug 11 01:05:21 IST 2021 - INFO - Successfully downloaded module Docker_Community_Edition_CE
Wed Aug 11 01:05:21 IST 2021 - INFO - Downloading component Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container
Wed Aug 11 01:05:21 IST 2021 - INFO - Sending request to download module 605c68865a4b53002c27264d
Wed Aug 11 01:05:22 IST 2021 - INFO - Sending request to validate module 605c68865a4b53002c27264d with hash value fad47dd64eed3c693c587efd6449708f
Wed Aug 11 01:05:23 IST 2021 - INFO - Module validation passed for 605c68865a4b53002c27264d
Wed Aug 11 01:05:23 IST 2021 - INFO - Successfully downloaded module Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container
Wed Aug 11 01:05:23 IST 2021 - INFO - Downloading component Docker_Compose
Wed Aug 11 01:05:23 IST 2021 - INFO - Sending request to download module 5f213aae9e63c9002a6fd88e
Wed Aug 11 01:05:24 IST 2021 - INFO - Sending request to validate module 5f213aae9e63c9002a6fd88e with hash value da574df823cb3f64fd751fa2b612b4e5
Wed Aug 11 01:05:24 IST 2021 - INFO - Module validation passed for 5f213aae9e63c9002a6fd88e
Wed Aug 11 01:05:24 IST 2021 - INFO - Successfully downloaded module Docker_Compose
Wed Aug 11 01:05:24 IST 2021 - INFO - Downloading component edgex_foundry
Wed Aug 11 01:05:24 IST 2021 - INFO - Sending request to download module 605c6d045a4b53002c272654
Wed Aug 11 01:05:25 IST 2021 - INFO - Sending request to validate module 605c6d045a4b53002c272654 with hash value 290d2a48673f86e6dced01134bd8a3ac
Wed Aug 11 01:05:26 IST 2021 - INFO - Module validation passed for 605c6d045a4b53002c272654
Wed Aug 11 01:05:26 IST 2021 - INFO - Successfully downloaded module edgex_foundry
Wed Aug 11 01:05:26 IST 2021 - INFO - Downloading component ONNX_Runtime
Wed Aug 11 01:05:26 IST 2021 - INFO - Sending request to download module 606ecbb5b6706a00391e1cb3
Wed Aug 11 01:05:27 IST 2021 - INFO - Sending request to validate module 606ecbb5b6706a00391e1cb3 with hash value 5d33ce6d31bd3920223caa47bd52f508
Wed Aug 11 01:05:27 IST 2021 - INFO - Module validation passed for 606ecbb5b6706a00391e1cb3
Wed Aug 11 01:05:27 IST 2021 - INFO - Successfully downloaded module ONNX_Runtime
Wed Aug 11 01:05:27 IST 2021 - INFO - Downloading component RI_MultiCamera_Social_Distancing
Wed Aug 11 01:05:27 IST 2021 - INFO - Sending request to download module 605c6f665a4b53002c272658
Wed Aug 11 01:05:29 IST 2021 - INFO - Sending request to validate module 605c6f665a4b53002c272658 with hash value dc2bdbdd74171db1973ed9b7ce89b543
Wed Aug 11 01:05:30 IST 2021 - INFO - Module validation passed for 605c6f665a4b53002c272658
Wed Aug 11 01:05:30 IST 2021 - INFO - Successfully downloaded module RI_MultiCamera_Social_Distancing
Wed Aug 11 01:05:30 IST 2021 - INFO - Downloading component Connect_Edge_Devices_to_Azure_IoT
Wed Aug 11 01:05:30 IST 2021 - INFO - Sending request to download module 605c70a95a4b53002c27265b
Wed Aug 11 01:05:31 IST 2021 - INFO - Sending request to validate module 605c70a95a4b53002c27265b with hash value 33a2a9a7ae6d97e486f15159f1946834
Wed Aug 11 01:05:32 IST 2021 - INFO - Module validation passed for 605c70a95a4b53002c27265b
Wed Aug 11 01:05:32 IST 2021 - INFO - Successfully downloaded module Connect_Edge_Devices_to_Azure_IoT
Wed Aug 11 01:05:32 IST 2021 - INFO - Downloading component esdq/Vision_Test_Module
Wed Aug 11 01:05:32 IST 2021 - INFO - Sending request to download module 608a3d977bc123002b7ebe8b
Wed Aug 11 01:05:36 IST 2021 - INFO - Sending request to validate module 608a3d977bc123002b7ebe8b with hash value 5827fbb1e86e130432018d88baefc7da
Wed Aug 11 01:05:36 IST 2021 - INFO - Module validation passed for 608a3d977bc123002b7ebe8b
Wed Aug 11 01:05:36 IST 2021 - INFO - Successfully downloaded module esdq/Vision_Test_Module
Wed Aug 11 01:05:36 IST 2021 - INFO - Downloading component esdq
Wed Aug 11 01:05:36 IST 2021 - INFO - Sending request to download module 6077ecafb6706a00391e1e61
Wed Aug 11 01:05:41 IST 2021 - INFO - Sending request to validate module 6077ecafb6706a00391e1e61 with hash value 05497c279503f54b63f7e516d796f2cb
Wed Aug 11 01:05:42 IST 2021 - INFO - Module validation passed for 6077ecafb6706a00391e1e61
Wed Aug 11 01:05:42 IST 2021 - INFO - Successfully downloaded module esdq
Wed Aug 11 01:05:42 IST 2021 - INFO - Downloading component esdq/VATS_Test_Module
Wed Aug 11 01:05:42 IST 2021 - INFO - Sending request to download module 6074a373b6706a00391e1cbf
Wed Aug 11 01:05:42 IST 2021 - INFO - Sending request to validate module 6074a373b6706a00391e1cbf with hash value 9bc71cbc32c1a8436dc9a6a3db799855
Wed Aug 11 01:05:43 IST 2021 - INFO - Module validation passed for 6074a373b6706a00391e1cbf
Wed Aug 11 01:05:43 IST 2021 - INFO - Successfully downloaded module esdq/VATS_Test_Module
Wed Aug 11 01:05:43 IST 2021 - INFO - Downloading modules completed...
Wed Aug 11 01:05:43 IST 2021 - INFO - Installing shared module 'esb_common'
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the shared module 'esb_common'...
Wed Aug 11 01:05:43 IST 2021 - INFO - Successfully installed shared module 'esb_common'.
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the module Amazon_Web_Services_Greengrass_Prerequisites...
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the module K3s_Lightweight_Kubernetes...
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the module Azure_IoT_Edge_Prerequisites...
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the module Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Deep_Learning_DL_Streamer_Pipelines...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Docker_Community_Edition_CE...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Docker_Compose...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module edgex_foundry...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module ONNX_Runtime...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module RI_MultiCamera_Social_Distancing...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Connect_Edge_Devices_to_Azure_IoT...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module esdq/Vision_Test_Module...
Wed Aug 11 01:05:45 IST 2021 - INFO - Unzipping the module esdq...
Wed Aug 11 01:05:45 IST 2021 - INFO - Unzipping the module esdq/VATS_Test_Module...
Wed Aug 11 01:05:45 IST 2021 - INFO - Modules to be installed by package are ['Amazon_Web_Services_Greengrass_Prerequisites', 'K3s_Lightweight_Kubernetes', 'Azure_IoT_Edge_Prerequisites', 'Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime', 'Deep_Learning_DL_Streamer_Pipelines', 'Docker_Community_Edition_CE', 'Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container', 'Docker_Compose', 'edgex_foundry', 'ONNX_Runtime', 'RI_MultiCamera_Social_Distancing', 'Connect_Edge_Devices_to_Azure_IoT', 'esdq']
Wed Aug 11 01:05:45 IST 2021 - INFO - Imported module for Amazon_Web_Services_Greengrass_Prerequisites is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Amazon_Web_Services_Greengrass_Prerequisites/esb_install.so'>
Wed Aug 11 01:05:45 IST 2021 - ERROR - Failed to verify the installation status of the component due to error Expecting value: line 1 column 1 (char 0)
Wed Aug 11 01:05:45 IST 2021 - INFO - Installing Amazon_Web_Services_Greengrass_Prerequisites
Wed Aug 11 01:06:01 IST 2021 - INFO - Successfully installed Amazon_Web_Services_Greengrass_Prerequisites took 16.47 seconds
Wed Aug 11 01:06:01 IST 2021 - INFO - Successfully updated status in log file for Amazon_Web_Services_Greengrass_Prerequisites
Wed Aug 11 01:06:01 IST 2021 - INFO - Imported module for K3s_Lightweight_Kubernetes is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/K3s_Lightweight_Kubernetes/esb_install.so'>
Wed Aug 11 01:06:01 IST 2021 - INFO - Installing K3s_Lightweight_Kubernetes
Wed Aug 11 01:06:17 IST 2021 - INFO - Successfully installed K3s_Lightweight_Kubernetes took 15.41 seconds
Wed Aug 11 01:06:17 IST 2021 - INFO - Updating status in log file for K3s_Lightweight_Kubernetes as SUCCESS
Wed Aug 11 01:06:17 IST 2021 - INFO - Successfully updated status in log file for K3s_Lightweight_Kubernetes
Wed Aug 11 01:06:17 IST 2021 - INFO - Imported module for Azure_IoT_Edge_Prerequisites is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Azure_IoT_Edge_Prerequisites/esb_install.so'>
Wed Aug 11 01:06:17 IST 2021 - INFO - Installing Azure_IoT_Edge_Prerequisites
Wed Aug 11 01:07:08 IST 2021 - INFO - Successfully installed Azure_IoT_Edge_Prerequisites took 50.71 seconds
Wed Aug 11 01:07:08 IST 2021 - INFO - Updating status in log file for Azure_IoT_Edge_Prerequisites as SUCCESS
Wed Aug 11 01:07:08 IST 2021 - INFO - Successfully updated status in log file for Azure_IoT_Edge_Prerequisites
Wed Aug 11 01:07:08 IST 2021 - INFO - Imported module for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime/esb_install.so'>
Wed Aug 11 01:07:08 IST 2021 - INFO - Installing Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime
Wed Aug 11 01:24:37 IST 2021 - INFO - Successfully installed Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime took 17 minutes 29.78 seconds
Wed Aug 11 01:24:37 IST 2021 - INFO - Updating status in log file for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime as SUCCESS
Wed Aug 11 01:24:37 IST 2021 - INFO - Successfully updated status in log file for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime
Wed Aug 11 01:24:38 IST 2021 - INFO - Imported module for Deep_Learning_DL_Streamer_Pipelines is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Deep_Learning_DL_Streamer_Pipelines/esb_install.so'>
Wed Aug 11 01:24:38 IST 2021 - INFO - Installing Deep_Learning_DL_Streamer_Pipelines
Wed Aug 11 01:24:48 IST 2021 - INFO - Successfully installed Deep_Learning_DL_Streamer_Pipelines took 10.08 seconds
Wed Aug 11 01:24:48 IST 2021 - INFO - Updating status in log file for Deep_Learning_DL_Streamer_Pipelines as SUCCESS
Wed Aug 11 01:24:48 IST 2021 - INFO - Successfully updated status in log file for Deep_Learning_DL_Streamer_Pipelines
Wed Aug 11 01:24:48 IST 2021 - INFO - Imported module for Docker_Community_Edition_CE is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Docker_Community_Edition_CE/esb_install.so'>
Wed Aug 11 01:24:48 IST 2021 - INFO - Installing Docker_Community_Edition_CE
Wed Aug 11 01:25:50 IST 2021 - INFO - Successfully installed Docker_Community_Edition_CE took 1 minutes 2.17 seconds
Wed Aug 11 01:25:50 IST 2021 - INFO - Updating status in log file for Docker_Community_Edition_CE as SUCCESS
Wed Aug 11 01:25:50 IST 2021 - INFO - Successfully updated status in log file for Docker_Community_Edition_CE
Wed Aug 11 01:25:50 IST 2021 - INFO - Imported module for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container/esb_install.so'>
Wed Aug 11 01:25:50 IST 2021 - INFO - Installing Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container
Wed Aug 11 01:26:38 IST 2021 - INFO - Successfully installed Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container took 48.15 seconds
Wed Aug 11 01:26:38 IST 2021 - INFO - Updating status in log file for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container as SUCCESS
Wed Aug 11 01:26:38 IST 2021 - INFO - Successfully updated status in log file for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container
Wed Aug 11 01:26:38 IST 2021 - INFO - Imported module for Docker_Compose is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Docker_Compose/esb_install.so'>
Wed Aug 11 01:26:38 IST 2021 - INFO - Installing Docker_Compose
Wed Aug 11 01:26:43 IST 2021 - INFO - Successfully installed Docker_Compose took 4.82 seconds
Wed Aug 11 01:26:43 IST 2021 - INFO - Updating status in log file for Docker_Compose as SUCCESS
Wed Aug 11 01:26:43 IST 2021 - INFO - Successfully updated status in log file for Docker_Compose
Wed Aug 11 01:26:43 IST 2021 - INFO - Imported module for edgex_foundry is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/edgex_foundry/esb_install.so'>
Wed Aug 11 01:26:43 IST 2021 - INFO - Installing edgex_foundry
Wed Aug 11 01:26:58 IST 2021 - INFO - Successfully installed edgex_foundry took 15.06 seconds
Wed Aug 11 01:26:58 IST 2021 - INFO - Updating status in log file for edgex_foundry as SUCCESS
Wed Aug 11 01:26:58 IST 2021 - INFO - Successfully updated status in log file for edgex_foundry
Wed Aug 11 01:26:58 IST 2021 - INFO - Imported module for ONNX_Runtime is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/ONNX_Runtime/esb_install.so'>
Wed Aug 11 01:26:58 IST 2021 - INFO - Installing ONNX_Runtime
Wed Aug 11 01:41:44 IST 2021 - ERROR - Failed to install ONNX_Runtime took 14 minutes 46.26 seconds
Wed Aug 11 01:41:44 IST 2021 - INFO - Updating status in log file for ONNX_Runtime as FAILED
Wed Aug 11 01:41:44 IST 2021 - INFO - Successfully updated status in log file for ONNX_Runtime
Wed Aug 11 01:41:45 IST 2021 - INFO - Imported module for RI_MultiCamera_Social_Distancing is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/RI_MultiCamera_Social_Distancing/esb_install.so'>
Wed Aug 11 01:41:45 IST 2021 - INFO - Installing RI_MultiCamera_Social_Distancing
Wed Aug 11 01:42:37 IST 2021 - INFO - Successfully installed RI_MultiCamera_Social_Distancing took 52.29 seconds
Wed Aug 11 01:42:37 IST 2021 - INFO - Updating status in log file for RI_MultiCamera_Social_Distancing as SUCCESS
Wed Aug 11 01:42:37 IST 2021 - INFO - Successfully updated status in log file for RI_MultiCamera_Social_Distancing
Wed Aug 11 01:42:37 IST 2021 - INFO - Imported module for Connect_Edge_Devices_to_Azure_IoT is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Connect_Edge_Devices_to_Azure_IoT/esb_install.so'>
Wed Aug 11 01:42:37 IST 2021 - INFO - Installing Connect_Edge_Devices_to_Azure_IoT
Wed Aug 11 01:43:41 IST 2021 - INFO - Successfully installed Connect_Edge_Devices_to_Azure_IoT took 1 minutes 4.28 seconds
Wed Aug 11 01:43:41 IST 2021 - INFO - Updating status in log file for Connect_Edge_Devices_to_Azure_IoT as SUCCESS
Wed Aug 11 01:43:41 IST 2021 - INFO - Successfully updated status in log file for Connect_Edge_Devices_to_Azure_IoT
Wed Aug 11 01:43:41 IST 2021 - INFO - Imported module for esdq is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/esdq/esb_install.so'>
Wed Aug 11 01:43:41 IST 2021 - INFO - Installing esdq
Wed Aug 11 01:43:48 IST 2021 - INFO - Successfully installed esdq took 6.34 seconds
Wed Aug 11 01:43:48 IST 2021 - INFO - Updating status in log file for esdq as SUCCESS
Wed Aug 11 01:43:48 IST 2021 - INFO - Successfully updated status in log file for esdq
Wed Aug 11 01:43:49 IST 2021 - INFO - Sending installation report
Wed Aug 11 01:43:50 IST 2021 - INFO - Installation report was successfully sent.
Wed Aug 11 01:43:50 IST 2021 - INFO - Installation of package complete
$ cat /var/log/esb-cli/Edge_Software_Device_Qualification_3.0/esdq/install.log
Wed Aug 11 01:43:41 IST 2021 - INFO - ----------------------------------------
Wed Aug 11 01:43:41 IST 2021 - INFO - Starting installation ESDQ_INSTALL
Wed Aug 11 01:43:41 IST 2021 - INFO - Starting main installation ESDQ_INSTALL
Wed Aug 11 01:43:42 IST 2021 - INFO - Setting execute permission to /home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/esdq/esdq
Wed Aug 11 01:43:42 IST 2021 - INFO - ----------------------------------------
Wed Aug 11 01:43:42 IST 2021 - INFO - Starting installation ESDQ_INSTALL
Wed Aug 11 01:43:42 IST 2021 - INFO - Starting main installation ESDQ_INSTALL
Wed Aug 11 01:43:42 IST 2021 - INFO - Installing ESDQ packages: zip
premp
Also another observation I had was, even though the ONNX build fails in report I still see that ONNX test sample is passed.
JesusE_Intel
Hi premp,
Did you previously have ONNX installed on your Ubuntu 18.04 system? Is this system a fresh Ubuntu install?
Also, it looks like you are using ESDQ 3.0, do you see the same behavior using the latest ESDQ 4.0 release?
Jesus
