Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
Edit MQTT configuration
HuynhVanThuan
Currently I'm having a problem with configuring MQTT. I conldn't find this configuration file after reinstalling my ubuntu OS. How should i get this configuration file in my computer.
Huynh
JesusE_Intel
Hi Huynh,
I am not familiar with the guide you are following and if there is any specific settings are needed before updating the config file. However, from a generic Linux perspective uninstalling the package should generate the default configuration file.
sudo apt purge --autoremove -y mosquitto
sudo apt install mosquitto
Jesus
JesusE_Intel
Hi Huynh,
Jesus
HuynhVanThuan
Hi JesusE,
Thanks for your supports. These command lines are really helpful with me so i can consider this as your right solution.
Regard,
Huynh
JesusE_Intel
Thank you for confirming. If you need any additional information, please submit a new question as this thread will no longer be monitored.
