I have difficulty installing ESC in my NUC with Ubuntu.
Package Name: Intel® Edge Software Configurator v4.0
Product Name: Intel(R) Client Systems
CPU SKU: Intel(R) Core(TM) i7-6770HQ CPU @ 2.60GHz
Memory Size: 16 GB
Operating System: Ubuntu 18.04.5 LTS
Kernel Version: 5.4.0-107-generic
Accelerator: None
CPU Utilization: 0.4%
Available Disk Space: 427 GB
I tried many times but I've got the message attached. May I ask if someone solve the same issue before?
Hi Shigeyoshi,
May I know if you can retry the installation command with sudo along? This is because the docker is required to pull the container from the registry.
sudo ./edgesoftware install
Thanks and regards,
Lim Xiang Yang
Hi Shigeyoshi,
Thanks and regards,
Lim Xiang Yang
Hi Lim,
Thank you so much.
I reboot the NUC several times and now the installation is successfully done. I didn't change any and don't know the reason, but any way I can move on. I appreciate your prompt response.
Ohara
